Craftsman drill press
Nmhuntr
Any idea what model craftsman this is and what the part is that is missing that retrieves the quil?
FrankLee
seMI, 48317
I'm not sure of the model number, but it's mid-'30s Atlas-made.
The feed return spring and housing are missing. I believe this style fits (not mine): https://www.ebay.com/itm/315248424032 .
The pinion shaft is pushed out to the left, so there is a pinion shaft collar loose or missing on the right. I don't see a feed handle rod either. Right side photo?
I don't believe that model had the chrome spire.
N
Nmhuntr
Thanks
I was thinking 30s Atlas made as well. I can grab it up fairly cheap but that return spring is missing and I wanted to be sure something was available. There is a feed handle but it is just the old style 2 hand spot deals not a 3 one
FrankLee
seMI, 48317
Atlas branded drill presses would have had the 3-handle hubs. Craftsman branded Atlas drill presses have 4 handles. I believe the hubs would fit on the rod handle pinion shafts. I have three spare 4-handle hubs. If you get that machine, you can have a hub for shipping cost.
