Craftsman Industrial doesn't fit?
chaser
I bought a set of 11, SAE Crafstman Industrial wrenches on close-out from a Sears clearance center near me. I went to use the 1/2 wrench to tighten down a nut and it didn't fit - either the open or closed end :mad::mad:
My S/K 1/2 socket fit over the nut easily, so i know I wasn't trying to force the wrong size.
Anyone else run into this with brand new tools? Does it take some time to get the chrome worn a bit for a better fit?
Puzzled to be sure!
FiveFinger
I had a 10mm craftsman raised panel wrench that the box end was a little too tight to fit MOST fasteners. The open end fitted fine. I swapped it out and the new one worked fine. That was before they started having chinese **** and I got a good quality wrench in return. That is the only wrench that I have ever had that was like that.
Farmall450
Marengo, Illinois
My brother had that problem with a metric wrench in that size range.
C
chaser
Hmmmm....mine are stamped 'USA' so I assumed high quality. The chrome sure looks good! Well, maybe I'll run over to Sears and see if I can swap this one out for another Industrial series wrench and see if it fits better.
Kinda pissed actually! Spend a bunch of money on supposedly quality and a wrench doesn't fit?
SMKS
USA, planet Earth
Since you got them on super closeout, you actually didn't probably spend "a bunch of money," you got a really good deal.
Still ***** that you got a bad one, though.
stratman977
Belle Vernon, PA
Compare it to another 1/2 or a maybe a 12mm. The wrong wrench blank could have gotten mixed in before they were stamped with the size.
I had a SK wrench with the swivel socket on the end that was a 13mm wrench but had a 12mm socket on it. Took me a while to figure out what was wrong with it until I measured the socket end. They warrantied it no question.
SMKS
USA, planet Earth
This is my guess.
Perhaps a metric blank or otherwise the wrong size was put in the wrong bin and then stamped "1/2"
NC-Fordguy
^This
I experienced this with an armstrong set a while back. I bought this set from my local Napa and they handled getting it right.
carterbeauford
NW PA
Outlet might or might not open a box and swap one out, regular Sears won't have that wrench.
measure the open end with a caliper. call Apex 800 688 8949 with the number on the wrench and they'll send you a new one.
justanengineer
Motor City
Was the bolt in question really 1/2" or did it happen to be 13mm? Ive got many standard closed end wrenches that wont fit the supposed "equivalent" metric size bc theyre not equivalent. Personally, I consider a tighter wrench fit a higher quality after having many 12 pt wrenches that successfully rounded off 6 pt bolt heads.
C
chaser
Great thoughts here, thank you!
Yeah for sure it was stamped 1/2 in since the S/K socket fit over it no problem. The wrong blank stamped wrong makes sense. I'll give that number a call.
Well I did buy the wrenches on close-out and didn't pay a ton, but still, expected better for the money. If I had paid full retail, I'd be really, really pissed!
Thanks again!
C
chaser
Well there you go. 1/2 and 13mm are the exact same!
C
chaser
Wait a minute, here's the real kicker: on the 1/2 wrench, the nut fits the closed end but not the open end. Its so close!!! I'll just give the number a call and ask them about it. Thanks again guys for all the help!
Milton Shaw
Check the other sizes to be sure it's just the one wrench that's the wrong size. I would hate to go through all that trouble on swapping one wrench to find another the next time I used the set.
Hootbro
Delaware
If you still have the parts listing with the service number, call APEX and tell them your problem. I bet they send you a new one.
b1ghwx
Iowa
That's really frustrating. You could have bought just as nice a set of China **** but instead you paid double for the US made ****. Its no wonder Sears is almost out of business.
Hootbro
Delaware
I have had truck brand tools that were out of spec also. I just did not let it make my world fall apart and dealt with it until it could be rectified.
Quite a bit a extra drama here and considering how many other posts there is on these tools, the vast majority are not having problems.
**** happens, deal with it.
carterbeauford
NW PA
I wouldn't call these wrenches ****, this appears to be a fluke happening. They aren't sold at Sears, rather Sears Outlet and Grainger.
pipsters
USA
My 14mm measures 13.99, which is kinda good because most 14mm fasteners are around 13.8 to 13.9. So it's really tight. Takes some effort to go straight onto a nut.
This stuff happens but the Industrial stuff will probably be gone shortly. I'm measuring all mine when I get back to make sure I don't have any duds.
franzdom
NC
It doesn't make sense that the 1/2" won't fit because you think it's actually a 13mm, if so it would fit even easier over a 1/2" hex. So I surmise it's a 13mm hex and the SK is sloppier than the craftsman which is probably the correct size to begin with.
dumper
Oregon
I would try the wrench on several so-called 1/2" fasteners before I went marching off to Sears. Were they HF nuts? Hahahaha..
tyheuser
I bet its a 13mm and your sk socket has seen some use and fits over the nut find a known 1/2 bolt or bring it to sears and try it on pro wrench. Its possible but that would be easy mistake to make!
Danglerb
SoCal
Get a high quality 99 cent HF caliper and measure both nut and wrench. Most likely cause is the nut is 13 mm not 1/2 inch.
