Craftsman Mach T handle 1/4 or 3/8?
ajchien
Los Angeles, stuck on the 60 freeway.
I'm looking at adding a craftsman Mach t handle to my toolbox. You know, that spinner tool. Not sure if the 1/4 or the 3/8 is the better tool.
As far as I'm concerned, I think I'd pretty much use it for 8 and 10mm fasteners, so either would "work". I figure the 1/4" would be lighter and easier to handle, yet the 3/8" would feel beefier and may spin with more momentum.
Anyone have both and can compare the two for me?
vjquan
The GJ crowd would say BOTH! For fasteners that small, I'd say the 1/4". The 3/8" would be too bulky.
zkling
I like the 3/8", unfortunately they are both the same overall size, just the 3/8" has a larger shaft diameter. It spins better due to the greater weight and has less flex in bending and torsion. With a 3/8 to 1/4" and 3/8 to 1/2" adapter it can do the widest variety without being too large or too small. Thank you SYW surprise points!
I'll add, if you primarily work with 1/4" sized sockets that are straight walled on the outside, the 1/4" version can shine as it will get deep into a recess and you won't have to worry about clearance as the largest point will be the socket instead of an adapter.
