Craftsman Motor Bracket
HunterMike
Colorado
So I just picked up a Craftsman 103.0103 Band Saw yesterday, and it came with this 3/4HP motor. I don't believe the motor originally went with the band saw, but since it was not mounted I can't be sure. My question, for you gurus, is what type of machinery have you seen this type of motor bracket on before? They also had a blue Craftsman table saw buried on the other side of the garage, so it could go to that? Not sure. Bracket is stamped S10-5.
Help appreciated.
jakemac
New England
That color blue on the motor looks correct for late-30's - early-40's era Craftsman motors. Is it a Craftsman, Dunlap, or Companion motor ?
Since most of the machines of that era had the option to buy the motor separately, the original owner may have bought a more powerful motor, or used one that he already had on hand from another machine.
The manual recommends a 1/3hp motor with either :
2" pulley on a 1750rpm motor
3" pulley on a 1140rpm motor
2" pulley on a 3450rpm motor AND change the 5" pulley on the saw to a 10" pulley.
The manual can be downloaded at vintagemachinery.org here :
http://www.vintagemachinery.org/pubs/detail.aspx?id=4696
Craptain
Tampa Bay FL
I am thinking lathe. I am not home right now to check but it looks familiar.
Sent from my SM-G900T using Tapatalk
H
HunterMike
Colorado
Jakemac,
I did see that in the manual as well. It is a craftsman branded motor. It does have a 2" pulley, and the saw has the 5" pulley.
Zeke & Zeeman, there was a blue table saw and a planer they had as well.
I must have gotten the wrong motor.
Thanks all for the reply's.
Craptain
Tampa Bay FL
The motor is fine. As l long as it runs. Just needs a new mount. 3/4 hp is great or even overkill.
