Craftsman Overdrive Sockets
Dankotaru
7000' ASL
I bought a small 49 piece 3/8dr Craftsman Overdrive socket set from Ace a few weeks ago. On sale at the time, and with a rewards coupon, it came out to $70. The set includes common standard and deep metric and SAE sizes, along with a 180 tooth ratchet. Here's a link to the set if you want to see everything included:
I don't care for the ratchet at all and will sell it. There's lots of YouTube reviews on the Craftsman Overdrive ratchet if you're curious to see an in-depth review of it, but in short, the head is huge and the backdrag high, and it's generally unpleasant to use compared to my "go-to" 3/8 ratchet: Matco88 flex head. I would never reach for it, so I don't plan to keep it. What I was really interested in with this set are the sockets because they have the 'RBRT' style flanks for a whole lot less than the MAC brand sockets, and I was curious to check them out. You can see the unique flank cuts:
Last weekend I needed to replace the driver's CV axle on our minivan (of course during what will likely be the coldest freaking weekend of the year in my unheated garage) and got to compare them to my older G1 USA Craftsman sockets and newer Proto sockets. What I found was interesting to me, and I figured it might be good feedback for others checking out the sockets. Especially since there are lots of reviews about the Overdrive wrenches but almost nothing about the sockets.
First, yes they are a darker gunmetal chrome like the wenches, if it matters. They look cool I guess, but I don't think the chrome looks anywhere near as nice as my Proto, and definitely not as nice as the few Williams and older SK sockets I also have. The insides are not clear coated, and there's some light rust on a few of the sockets. None of which is a big deal to me, but just FYI in case these things matter to whoever is reading this.
What concerns me is the fitment, and this is where the Overdrive sockets are interesting. The very first socket I grabbed was an 8mm to remove the sway bar end link. And the socket didn't fit. So I double-check the service manual, and yep, it's a 17mm nut on a 8mm end, but the 8mm socket didn't want to go over the end. So I check my other tools, and my 3/8dr G1 Craftsman fit on it, a 1/4dr Proto socket fit on it, and my Armstrong-made Craftsman Professional wrench fit just snug as a bug on the end of the thing:
So what's up with the Craftsman Overdrive 8mm socket? Turns out, it's made to a pretty tight tolerance:
And that's the thing, all these Overdrive sockets have tighter tolerances than anything else in my tool chest. The sway bar end link measured 8.13mm, so it is too fat for the Overdrive socket but all my other 8mm sockets/wrenches fit just fine. The 10, 14, and 17mm sockets in this set were all tighter than my other options while working on the minivan. On a brand new titanium bolt for my motorcycle with a 12mm hex head, the 12mm Overdrive socket felt like it snapped onto it, the bolt had no wiggle or movement at all once in the socket. Just super tight engagement. On worn fasteners, the only test I really had with a rounded head was a 14mm pinch bolt for the lower ball joint that has been worked over more than a few times with an impact, and the socket fit and gripped tight. I don't doubt their ability to work better on rounded fastener heads- if the socket fits.
I think I'm going to keep them because I really like their engagement - when they fit. I like having them as an option to use. But I could not recommend this as a primary socket set for someone, because you will come cross all manner of fasteners that are just outside the tolerances of these sockets and these will be a pain to use, compared to most any other normal socket or wrench, to remove the fastener. I suppose you could just try hammering it on, but I have specific bolt/nut extractor sockets that are designed to be hammered onto fasteners if I wanted to go that route.
Finally, another consideration before purchasing a Craftsman Overdrive set is the ability to source a replacement socket. I have had e-mail conversations with both Craftsman and SBD, and talked with Craftsman on the phone, and right now these sockets cannot be purchased or warrantied individually. Right now, if you wanted a single socket, like I wanted to buy just a 3/8 deep socket, you can't. And if you break one in a set, you can warranty it for a regular chrome socket from Craftsman or try and exchange it out of a set at your local Ace/Lowes. That kinda *****, and no one could tell me if individual Overdrive sockets will be available in the future.
Andres26tnt
^^^ not sure if you got confused by the use of kit. The kit is clearly labeled as a round off extractor type of tool. All these type of kits have tight tolerance to help remote rounded fasteners. I don't remember any promotional/advertising material mentioning it as a everyday use tool. Personally I feel like this should be common sense 😅, rounded fasteners are usually smaller.
The warranty issue is unfortunate. I imagine this is harder to warranty for them, as the kit is only produce to be sold in kits. Weird as they have like 5 or 6 similar kits available from their various brands. Must be different manufacturers for them. I agree they should have individual set apart for warranty.
Should you skip this product, do to the warranty issue? Imo no, it's a great product at a cheap cost, vs the high cost of it's brother(Mac RBRT). I'm very pleased with all the gunmetal chrome tools I have, specifically the wrenches. Only real drawbacks are the durability of the chrome and skipped sizes.
Fedwrench
Valley of the sun
Before RBRT became the tool of the day, about 20 years ago, MAC sold MAC Edge sockets and ratcheting wrenches with the same notches or cuts on three sides of the hex. They were made in Taiwan as well. What's old becomes new again :lol:
I think whoever is developing Craftsman Ratchets currently is an insider threat trying to destroy the brand from within. :bounce:
Hakeem
Chicago
The Overdrive wrenches are exceedingly tight on fasteners, as well. Certainly not the best choice for a primary wrench set.
Outstanding post, OP! I appreciate the thorough write-up and photos.
D
Dankotaru
7000' ASL
Maybe I misinterpreted their use, but I don't see Craftsman advertising this as "a round off extractor type of tool". Their pitch covers using them for "everyday maintenance and automotive applications" to prevent the rounding of fasteners, as well as the ability to remove worn fasteners rounded up to 70%. And like you said, these are the "brother" to the RBRT line, and MAC touts their RBRT as everyday use tools to prevent rounding, while also excellent for removing already rounded fasteners.
I agree that this product shouldn't be overlooked just because of the warranty. I just wanted to make sure anyone considering buying a kit, especially the larger kits (the 284pc kit is pretty complete for socket sizes with no skips) understands there will likely be fasteners the sockets won't fit, and warrantying a broke one (especially if the size isn't in a smaller kit) could be difficult.
D
Dankotaru
7000' ASL
Yeah, I thought the ratchet to be shockingly bad.
Interesting info on the older MAC Edge sockets. Do you know, did they sell well at the time? Because everyone seems to love the RBRT stuff now.
D
Dankotaru
7000' ASL
That's good to know about the wrenches also being tight, I was wondering if that's also the case.
Like I said, I will keep the ones I have because I like the tight engagement, but yeah, I agree these are not the best choice for a primary set.
Andres26tnt
I'm just mentioning that common sense should prevail in this type of product. Every single extractor or tool for rounded fasteners I've used, or seen videos mention this "issue". It's not an issue, it's by design. The tools purpose is to remove 70% rounded fasteners, those fasteners are always undersized do to the rounding.
Craftsman advertises them to extract up to 70% rounded so most definitely fits the wording. Extract or remove same, same. But like always they have mumbo jumbo in the advertisment. I can see the confusion due to the advertisement. It's not an everyday tool, I agree craftsman is wrong in advertising it a such.
Fedwrench
Valley of the sun
I don't think they did that well because they were imported, and the line up consisted of only a few items. Flash forward to today and it's a different story because MAC started off with bit sockets, extractors, bits, and then added wrenches & sockets later. Imported tools are more widely accepted now.
dchawk81
I have the RBRT wrenches and they're a PITA for everyday use.
dchawk81
Everyone knows marketing executives are sadists. 50 Shades of Chrome Vanadium.
Andres26tnt
The Mac edge are still being sold under various names from other vendors. They aren't the same, just similar. Social media has change the game with tools, that why Mac RBRT sold better.
nbpt100
Massachusetts
I just saw a sizable display of these at my Lowes and I did not think these were not intended for everyday use. I am not a tool novice as many people buying at Box Stores are. Some will be buying gift items purchased by a well meaning son/daughter/wife etc. I suspect there will be a fair number of frustrated users over the coming months. Selling these with a ratchet implies it is an every day socket set. Specialty square drive sockets are typically not sold with a ratchet. They should sell them with out a ratchet and make it a bit more affordable for the rest of us. And please do not skip sizes! As Craftsman has been known to do.
The combination wrenches caught my eye because they were 6 point and you do not see that very often. I recall posts from years ago where people where asking who has a decent 6 pt box wrench. I had an SK set once that was bought about 30 yrs back. Otherwise I do not know of another brand that has recently sold 6pt combination wrenches. I am sure SO does but that is beyone the cost most can stomach.
I think it's a great idea and many GJer's would benefit to have some for that right moment. Tools like this can save incredible time when understood and used correctly.
D
Dankotaru
7000' ASL
Yeah, as mentioned earlier, they are marketed as everyday use tools. Craftsman advertises them to work on rounded fasteners, and also to use everyday to prevent rounding of new fastener heads.
I like using them on most things. For example, here is a shot of the Overdrive 10mm socket on a Ti hex bolt, and the engagement is so snug I can hold the socket and the bolt doesn't drop out:
This tight engagement translates to almost zero slop when using the sockets, which I like. They feel good to use, when they fit.
The problem is, just like on the 8mm drop link end in my first post, they don't always fit. Today, I was replacing some old carriage bolts with shorter ones so I can hide them behind the drywall when I finish my garage, and I re-used the old washer and nuts on the new bolts. The Overdrive 9/16 deep socket wouldn't fit over the nut. I presume because it had a coat or two of primer/paint on it:
The pic is after I already torqued them down with a ratcheting wrench which worked some of the paint off the nuts, but you can still see it wasn't a heavy coat on the hardware. My G1 Craftsman 9/16 deep went over it without a problem, as did my Gearwrench wrench, but the Overdrive didn't want to engage. I could have forced it on, but it was easier to just grab another socket instead.
I figure these will work great for maybe 80-90% of all the times you need a socket, and they'll be really handy on rounded fasteners for sure. But like you mentioned, I also think there are going to be homeowners who get a set and then wonder why their new Overdrive sockets and wrenches, which are more expensive than regular Craftsman sets, are such a pain to get onto fasteners like this and feel misled.
