5mall5nail5
I find superlube TOO thick for the 84T's. Go with oil.
what kind of oil did you use? the 0w-30 castrol didn't help much...
wd 40
I use Marvel Mystery Oil in mine with good results. My 1/4 drive had issues when I got it, but after a thorough cleaning and relube, I haven't had any more problems. The 3/8 drive I got recently has been trouble free so far.
Not sure if this helps, but I'm using Silicote Reel Lube in my ratchets to good effect (silicone grease w/ PTFE). Went with this as I can find it locally instead of having to order SuperLube.
I used a dab of gear oil - it quieted them a ton.
red lube of love....![]()
Mine were just fine. No oil needed. I have all 3 sizes. Smooth as butter. I wish they would come out with a flex head version
sorry about your luck. if you can get in touch with somebody that will send you a rebuild kit. please pass that number on to me.
these seem to be hit and miss on QC. The one I received after exchanging my bad 3/8 has worked perfectly.
call them and ask if they have a rebuild kit.
These are available separately but not as a set. Will or have these been discontinued? I like these but if warranty replacements won't be available I will have to skip these as the thin profile and RP teardrop ratchets aren't a valid replacement.
