Craftsman Ratchet - Need Bearing help
Tvtrader
Ny
I enjoy taking an old ratchet and cleaning it up, lubing it and putting it back into service. Even if the plating comes off in spots if it is still serviceable I will use it.
Recently I have come across some ratchets that need bearings. I once saw a post where the author listed the correct size bearing needed for each ratchet.
usually it is the bearing near the Pawl that needs replacing.
I do have an RHFT ratchet that needs a bearing below the socket release button, not the one in the square drive that releases the socket, the one above it, on top of the spring.
Anyone familiar with this bearing?
I have seen the video on Youtube but they don't mention or show the bearing below the push button release.
seber
Deep East Tx.
Bearing balls are universal items. Any bearing house or even McMaster Carr should be able to help if you know the diameter.
T
Tvtrader
Ny
They are both apart.
The tri wing needs a single bearing by the pawl.
The RHFT has two bearings near each Pawl that are OK. It's the single bearing below the release button that broke.
T
Tvtrader
Ny
Thanks. There both 1/4 inch.
The RHFT has three bearings. Two by the pawl, and a broken one by the socket release button.
mikebaker1129
Huffman,TX
The triwing uses a plunger , not a bearing.
Let me check, I may have 1 in my ratchet parts.
As far as I know they are not available.
I will let you know when I check my ratchet parts.
T
Tvtrader
Ny
Here is a picture of the plunger
bonneyman
Desert SW
Worst comes to worse a more modern Stanley-made kit (like a Husky) will drop right in and work.
