lauver
Hip2u77,
Thanks for your post. I've run into the same situation (multiple series) in both sets and packaged sets; I bought a 19 piece 1/2" drive set in the early 90's with G sockets, H extensions & spark plug socket, and VG ratchet. It's seem to be a fairly common practice at Sears starting in the 1980's.
Regarding your finds, I have not seen the J WF, K WF, & VS series codes. Also have not seen VVV, although I have just recently (March 2003) seen VW.
If at all possible, can you recheck your latest ratchet--could your VVV be VW? Also, if you still have the VS ratchet, can you double check the series code and supply a C-man part number?
Thanks again!
Thanks again!
I will check that out. Thanks!!!
