Thanks much. That seems to be the consensus.Hello @Eddymeboy and welcome to the site!
keep this link handy
and this one!
As noted, while other tool manufacturers endeavored to invent part numbering systems for their sockets which made sense (generally ending with the two digits that corresponded to the socket opening size in 32nds of an inch), the Craftsman socket part numbering system makes absolutely no sense at all.
While a run of sizes may have sequential part numbers (e.g., 3/16" - 1/2"), you'll find oddball, out-of-sequence part numbers on items which may have been added to the catalog at a later date (e.g., 5/32")
here is another example - of metric socket part numbers - listed from a set I currently have on ebay:
10 mm 12 pt 44232 EE
11 mm 12 pt 44229 EE
12 mm 12 pt 44233 EE
13 mm 12 pt 44234 EE
14 mm 12 pt 44235 EE
15 mm 12 pt 44236 -VV-
15 mm 12 pt 44236 EE
16 mm 12 pt 44266 EE
17 mm 12 pt 44237 EE
17 mm 12 pt 44237 -VV
19 mm 12 pt 44238 -VV-
22 mm 12 pt 44239 -VV-
again, the Craftsman part numbering system on sockets makes absolutely no sense at all.
In which case you want to match the production codesTrying to keep the set as original as I can
If you're OCD, then you need to make sure all the sockets have the right series too.That makes sense. Trying to keep the set as original as I can so I wanted to be sure before pulling the trigger
They're -v- I'll be sure to keep that in mind.In which case you want to match the production codes
Craftsman Hand Tool Manufacturers & Date Ranges
(e.g., -V- or =V= (which are actually the same) or G or VV or.... )
For what it is worth, I found a complete set in a tool box I picked up recently. As far as I can tell it looks original and complete with the metal flip-top case, socket finishes look the same across the set (with a weird rough inside finish) but they are a mix of V, VV, and G.... set of older -V- deep chrome six point 3/8 drive sockets, I just realized the only one I'm missing is the 7/8 number 43339...
A lot of sockets from that era have an inside finish that is like a type of paint. Usually wears off with some use. At least those Craftsman sockets were from before the **** double detent started so that is a plusFor what it is worth, I found a complete set in a tool box I picked up recently. As far as I can tell it looks original and complete with the metal flip-top case, socket finishes look the same across the set (with a weird rough inside finish) but they are a mix of V, VV, and G.
That is exactly it. A few of them have worn paint inside. Thanks!A lot of sockets from that era have an inside finish that is like a type of paint. Usually wears off with some use. At least those Craftsman sockets were from before the **** double detent started so that is a plus
Just came across this thread, very valuable info. I was just going thru a bunch of random drawers and leftover flea market scores etc. and such and have pieced together a complete set of older -V- deep chrome six point 3/8 drive sockets, I just realized the only one I'm missing is the 7/8 number 43339.
Based on the old catalog chart above, I see there was nothing smaller than 3/8 and nothing larger than 7/8 in this particular series/era of 3/8 drive.
I think it's odd they picked 7/8 as the largest and not 3/4. There are tons and tons of sets (to the point it's extremely common, esp in wrench sets) to go from 3/8 to 3/4. Most sets that go above 3/4 run all the way up to 1 inch. Here, they include 13/16 and 7/8 and then stop. The 13/16 and 7/8 in this set/series are not "spark plug sockets" either, with the rubber boots inside etc, they are just ordinary sockets.
