Craftsman speed-handle disassembly
cherryred
Pittsburgh, PA
How were the spinning handles on these assembled and is it at all possible to disassemble to replace bearings? Right now the only thing I can do to keep it running smooth is drip 3-in-1 oil down inside. CrAftsman =v= U.S.A 4427
Beerhippie
Far NE Oregon
The outer piece was pressed on, then the rim rolled over to retain it.
You could disassemble it, but it would never look the same again--in my experience.
rust in the eye
Chicagoland
Flushing with WD40 or similar, spinning with a bit of force applied from various directions will eventually grind out all the **** and corruption. You'll need to "rinse and repeat" as needed until the flushing oil comes out clean-ish. Not a perfect solution but it's worked for me, even on one that began frozen solid.
Good luck!
C
cherryred
Pittsburgh, PA
Mine arrived from eBay squeaky, but 3in1 fixed it. These things are like a puzzle to me though so I always want to know how to rebuild on the most elemental level. I guess for these it’s pretty serviceable to just use oil on the sealed system long term.
