Craftsman table saw 113.27610 replacement parts
mathewamundsen
UT
Need fence assembly for vintage Craftsman table saw, model 113.27610. Actually just the clamp rod, but the whole fence assembly is ok. Is this available anywhere?
mikegt4
sw ohio
It doesn't look too hard to make a clamp rod up, at least according to the diagram in the owner's/parts manual. Ebay is probably the best place to find a fence but prices won't be cheap.
mathewamundsen
UT
Here are a few pictures. The clamp rod broke off inside the clamp lever. Not sure how to get the insert out of the lever, if I was to try just replacing the broken rod.
The Cobbler
can you tell if the rod is threaded in to the lever? I suspect it is. you can try to use a small punch & tap on it to loosen. a bit of fst heat on the lever could help to free it up too. if not, someone you know with a welder could weld a nut on to the rod & turn it out. a new rod looks straightforwrd .
If you post a location someone on here might step up to help you
tenor66
Does anyone know if all of the 113 table saws share the same wing extensions? Will extensions from a 70s or 80s model 113 fit the much older 113s from the early days of the model? Thanks
CKS1955
Good evening,
They are pretty much interchangeable (assuming 20” wide x 27” length top). Although , you may have to drill holes in the cast iron top depending on hole placement. But cast iron is pretty easy to drill.
Jay
