The fence was a question I had. I read that they ****, and I am sure they do, but I am not sure why. The one I have locks on and is VERY sturdy and seems to be easily adjustable. I cannot budge this thing when it is set. Is it a parallel issue with the blade? What do I need to do to improve this? I'm a newb to table saws, but have some planned projects that will require it and want to be sure I am ready.
That old type of fence clamps or locks onto the table front and back. The problem is that if you make a fine adjustment the friction of the fence sitting on the table makes it such that the front part near you will move but the back part won't and then you will lock the fence in not parallel to the blade. At minimum this can be inaccurate and at max it can be a danger of kickback.
What I always had to do was adjust the fence, kind of grab and wiggle the back of the fence to help square it but then had to recheck the measurement.
Yes the fence will work. Yes you can adjust it so that it is parallel, accurate, and even safe enough. But it is very annoying if you are doing a bunch of work on the saw. Frankly is just was ******* me off.
Changing to a modern Tsquare type fence was easy and made a world of difference in the use of the saw. I would never go back to that old fence.
If you can weld and fabricate a little you can make a copy of a biesmeyer type fence for not that much money. I bought my vega fence for a bargain or I was going to just make one
I have a shaper, but if I didnt I would look at the newer unisaws and how they do their side extensions. Basically just a Formica covered table top type thing with a couple of legs. Then make an insert so you can drop your router into it to make like a shaper/router table. You will be able,to use your fence and even the miter gauge if you place the router close to the edge of the saw. Actually I would make two drop in locations for the router. One near the saw table and one out at the end
Bob
