Craftsman Table Saw
subroc
Dover, NH
$20? Well, sure, $20 is a good price. That said, there are a few things about those 8" saws that are unique. If any of those unique things are missing or damaged or broken a replacement could be as much as 5 times what you paid for the saw. caution is the rule of the day when looking at old machinery.
Smiles79
Northwest Missouri
Can you tell me what these unique things are?
subroc
Dover, NH
The handwheel, the double gear, the motor mount, and the elevation parts with that ball assy.
I say unique but that is compared to the abundance of the 10" saws and parts that are availble.
FrankLee
seMI, 48317
Click the link subroc provided above. Then click the publication reprints tab, sort by pub title, scroll down and find your manual. Motor mounting instructions are there.
If you need a motor mount, I have one available here:
I also have the motor alignment rod which appears you're missing.
Check your tilt control gear. They often are fubar. I also have that.
Smiles79
Northwest Missouri
I'll send you a pm!
Smiles79
Northwest Missouri
Well in my search for a motor for my saw, I found another one! Picked this one up for $25.
What's the best way to clean the table? I see it has a double pulley do I really need two belts?
I think I'm going to look for a fenc, and probably sell or part out the other saw
I prefer to use a razor blade, at a high angle, like a scraper, to get rid of the worst crud. Then an abrasive on a hard block, to avoid getting uneven spots as you may get from a power tool. If you have pits, Evaporust I think made a gel.
FrankLee
seMI, 48317
I've used a razor blade on really thick rust like that, then I used a 1/4 sheet finishing sander.
This worked very well for me on many dozens of machines. (No, it does not damage the surface.)
