Craftsman Vari-Slo. I need a measurement please.
CalsXS2
Craftsman Vari-Slo. I need a measurement please. And how to repair a brake
I picked up an old Craftsman 100 last night. It has the vari-slo. But its missing the control knob on top.
I've found a close replacement I think. Does this knob look like the original with the ridge around it. If seen some with. And some with out the ridge. Don't know which is correct. I'm not going to be that **** about it. This is the knob I will use.
I need to cut it to length and re-thread it. Can I get a measurement from the bottom of the knob to the end of the threads. And then the length of the threads. Thanks
BTW. Post pics if you like.
A E Numan
Portland Oregon
Both of mine have the ridge around the knob. The shaft sticks out 1 7/8 and is threaded 3/4 in from the end.
C
CalsXS2
Thank you sir.
Is it 1-7/8 from the bottom of the ball like shown in my pic. Or is that with out the ball on it.
C
CalsXS2
I want to make sure I get this right.
Can you tell me where you are taking your measurements from. Are you unscrewing the rod out of the holder.
C
CalsXS2
From the bottom of the ball the rod sticks out 1 7/8 the last 3/4 is threaded. I hope that makes sense.
Yes it does. I think,,,lol.
If I'm understanding correct. You are unscrew the rod off of the machine??
From the bottom of the ball to the end of the rod is 1-7/8''.
The last 3/4'' is threaded.
Correct??
C
CalsXS2
Thanks Numan!!
I think my knob looks pretty close. I'm happy with it for a dollar,,,lol.
C
CalsXS2
Hears a picture, remember that you also need a "clamping pad"
My machinist buddy is going to try and make me one at work this week end. If not I'll make one when I start back to machinist school next week.
C
CalsXS2
Forgot about this part. Turns out the column support bracket is broken. Seems to be a common thing.
Have you guys had any luck welding them. Does the weld hold.
I could maybe make a new one. I wonder what would be the best material to make it out of. I could do billet aluminum, or steel. If I did aluminum, would it corrode with the steel column. Wounder why they didn't make them out of steel to begin with.
IDK. If you guys say a weld will hold, that would be much easier,,,lol.
Mine is broke where the red line is.
