Craigslist find - Quincy - Good Deal?
kspwski
Central Iowa
I found this posted on Craig's List this morning. It appears to be a Quincy QTS-3. I can't seem to find much detailed information about that particular compressor online. Also I can't tell what size of motor that is from the nameplate, appears to say "SPL" under the HP on the nameplate.
http://ames.craigslist.org/tls/2830056653.html
I'm going to go look at this in the afternoon, any ideas on if this is a good deal or not.
Also, anything to check or watch out for when I go see it? I thought I might pop the belt off an see if I could spin the pump/feel any compression. If it's got a drain valve on the bottom I'll see what's in the tank.
Thanks for your help!
AbitNutz
If it's 3 phase you're screwed but Quincy is likely the best compressor made....and this is coming from someone who has an Ingersoll-Rand
rwhite692
Central Valley, CA
Pic of motor plate info indicates it is single phase (PH - 1)
K
kspwski
Central Iowa
What is a "control air compressor". I'm the second guy to look at so I think I'm going to be sol....
Stuart in MN
Minneapolis
The ad is already deleted, but from the nameplate amps it's around 1.5hp. A control air compressor would be used to supply compressed air for a control system - for instance, to open or close pneumatically actuated valves in some manufacturing capacity.
1320stang
Edmond, OK
I work for an engineering firm that designs HVAC systems for big buildings. Used to be actuators for dampers and other devices were pneumatic and needed a compressed air supply. Control air is rarely used anymore in new construction, mostly in XP (explosion proof) situations, but there is still a lot of older stuff out there.
