Craigslist Purchase - Parts Washer
Chaznsc
SC
Picked this up today for $40 on CL. Its a Safety Kleen PW......pump works fine, so does the light. What sort of cleaner is recommended?
Vegaman_Dan
Pacific, WA
I am running a degreaser cleaner I bought at the dollar store for a half gallon. Filled it with about 8 of those and topped with water to make a strong solution. It is highly effective, no fumes, and isn't damaging to the pump, tank, or the parts to be washed.
Jagmandave
Overland Park, Ks.
I buy my solvent from Safety Kleen, yes it's a bit spendy and kerosene would probably work as well, but it lasts a long time and really cleans, and they'll exchange it for a new one when you're ready (for the appropriate fee, of course)
C
Chaznsc
SC
I want to be safe. This my home garage. Should I expect to get fumed out?
Tdoriot
I used odorless pain thinner. No smell. Works amazingly well. I wouldn't expose to a open flame however. I think the flash point for paint thinner is fairly high. Do a bit of research. If you used the cheaper stuff, your wife will kill you. It stinks!
drmarkr
Tucson
odorless pain thinner. Works fine, and minimal odor. I'm almost certain that it's the main ingredient in the SK product that they charge about 10 times as much for....
laser3kw
northen IL
I was a Safety Kleen rep back in the late 80's. The Safety Kleen green solvent was a 105º flash mineral sprit. The clear was 130º flash mineral sprit. Stoddert solvent is basically the same (petro family). Keep the lid down will keep the evaporation down.
C
Chaznsc
SC
My concern with OPT is that there is something added to it to make it odorless. I had let a bottle of the stuff sit idle in my shop and when I went to use it, it had separated, sort of looked like melted ice cream once it separates. There was a clear part and a white, milky thick substance. Now, I am no chemist, but the experience left me leery of the stuff.
jcinga
Acworth, GA
Yep, mineral spirits here also. It's getting pretty expensive at about $14.00+ per gallon. Like you said, Safety Kleen's green solvent is mostly mineral spirits. Look at the MSDS sheet for info on solvents.
porschedude996TT
Santa Maria, California
I have one of those, only it has a plastic 5 gal portable container that was to be exchanged with SK. It never did kick off like the company had hoped. I suspect that there were two reasons. One was the Local distributor was a real A$$ and didn't want anything to do with servicing private persons and they never setup an exchange location. I called him once about a mating rubber gasket that had swollen badly and was made out of an incompatable rubber. He couldn't be bothered...
The second reason is the flooding of cheap larger units like Harbor Freight that were larger and cheaper in the long run.
9GUY9
Mankato, MN
A water based degreaser will cause the unit to rust. I have been happy with the tractor supply solvent for several years.
C
Chaznsc
SC
Dumb question, but does the PW need to be filled to capacity?
laser3kw
northen IL
One thing caught my eye. Safety Kleen mineral spirts were always in a red drum. The "gray barrel" with the nasty sticker (black and withe diamond) was Safety Kleens carb cleaner. Originally it was methylene chloride (CAS #75-09-2) and used water to cap the liquid to keep it from eveaportating (water floats on top of methylene chloride) . The water would take on a white / yellow / tan appearance as it absorbed grime.
Safety Kleen was experimenting with new compound right as I left.
If you drip aluminum in it and it desolves after a while, it may be carb cleaner.
ptschram
Churubusco, IN
Nice score.
First things first, grind off where it says "property of Safety-Kleen" stamped in the back surface where the pipe that holds the lid open is attached ;)
In order to ensure longest life, fill the tank to where the pump is covered with plenty of solvent to ensure it won't run dry and that there is plenty of solvent to cool the pump.
The pumps should pretty much run forever, I've had mine for more than 30 years and the original pump is still running strong.
The Safety-Kleen guy who called on my mother's truck shop in the 70s showed up one day saying that he had gotten a great deal on refurbished Safety-Kleen machines that were being sold outright and did her shop want one. We bought several of them and one of them made it to my home shop. As a 17 year-old hot rodder, this was heaven.
Of course a month later another guy from Safety-Kleen showed up, told us the last guy had disappeared and that he was the new rep...
I still have that parts washer!
laser3kw
northen IL
:shocking:
I can neither confirm nor deny such things ever happened.
I know / heard stories for reps running across units that were sold / left behind / bought at auction etc., Most would sign it up as a customer owned and get the commission for the placement. Then who cares if the customer dumps the service later on. Hopefully when the next rep takes over......:evil:
911mike
michigan
i have tried several products over the years and so fat the TSC product PSC1000 works the best for me. I think a 5 gallon pail is $38.00
HTGTS350
When it comes to parts washers you have only 2 options for solvent, Kerosene or all that other ****.
miketyler
Cedar Hill, TX
I too have a Safety Kleen parts washer I bought off of CL. I think I picked up for $50 with the barrel? Its a green one and has served me well with flexible spout, power brush and fluorescent light built into the lid. You will be well served to keep the lid closed. As was mentioned this will keep the odor down but more important will preserve your solvent levels. Will see if I can snap a pic of it this weekend
