littletoes
Guys---Anyone know where connectors like these can be found??? I've been tearing the internet up, but can't find anything. These are out of the window switch on an '87 K5 Blazer.
Thank's for the help guys!
Gayler-I think you have a very close example on #188 or 546, but those connections look like they come in from the end (perhaps a GM 'improvement'?). Wish I could see the other side of the connector!
Don't know how you guys did this so fast.......Thanks again!
I wonder if the newer versions go in from the end???
This is supposed to be a forum where guys help each other, not display their concern for the adequacy of a design they've never seen before or don't understand. Or even worse using the thread to throw a jab at a manufacturer they may not like. What the OP is showing is part of a typical GM power window switch connector and while the part purchased new may be expensive, there are millions of them in boneyards and often are free for the clipping. That design has been in use for DECADES and is up to the task.
Those are "Pin Grip" terminals made by Delphi. They come straight like that, or at a right angle, like a flag terminal.
Is that picture from the door harness that plugs in to your door locks or window switches?
Do you need terminals or the whole connector with the pigtail? Mouser sells the terminals and some of the connectors. If you need the whole connector with a pigtail, there will be a GM part number for it, which a dealer can lookup.
BTW - I had to rebuild a wire harness in my '99 Firebird and needed some of these terminals. They were a total bear to find and I had to pour through hundreds of Delphi shop drawings to find the correct one. The emotional scars from that exercise are deep...
I have used http://terminalsupplyco.com to get Delphi connectors in small qtys in the past. I figured this would maybe help someone down the road. Not affiliated in any way.
I found these guys to be understocked and overpriced but they have most of the basics.
Other good sources of supply are:
- Mouser Electronics
- Eastern Shore Enterprises
dont know who this was directed towards but we were trying to help the fella. who's throwing jabs? jeebus dude. agree with boneyard
I'm pretty sure they are a smaller outfit. I usually try to support the smaller ones as pretty soon we'll only have Walmart's left to buy **** from but to each their own. When trying to find anything it's always good to have as many sources as you can. Better chances of actually getting what you need.
