Crazy Idea to convert a Landis Pipe threader into a Lathe
Movin/on
Brookings, Oregon
Many years ago I was given a Landis Pipe threader and just stuck it into the back of my shop. It's probably from the 1940's since it's got a 3" flat drive belt.
I've got the Manual somewhere and a large toolbox of the dies, Now what do I do with it?
It's probably 8 ft long and weighs (guess) over 1000#. It's complete with the 220V motor and switches. I've got it on casters.
Thinking of converting it to a rudimentary lathe just for a challenge/kicks. I do know the tolerances won't be that great but it does have about 12 " clearance to the bed.
Ideas? I'll try to get pictures in a few days. Not sure if I should have posted this in the Vintage Forum or Fabrication Forum instead.
Movin/on
RoninB4
Under My House
I doubt it would have the speed for a wood lathe. Changing the motor/pulleys will simply have the spindle rotating faster than the spindle bearings/bushings can handle and wear out in short order. As a metal lathe it's likely not rigid enough to handle the cutting forces. Not enough speed changes, capstan operated carriage, no tail stock. Not a great choice for conversion, especially if it's worth a good buck selling as is.
If it's really worth what Walkers (above poster) suggested then selling it to fund a purchase of proper machinery would be worth investigating. It may have enough mass but is the mass in the places it needs to be? Photo if you can.
PoorUB
Fargo, ND
Movin/on
I am with the sell it or scrap it and buy a lathe. I can not image anyone could build even a half *** usable lathe for reasonable money. Plus when you are done you have a cobbled up "something" that nobody wants.
