sdowney717
- Joined
- Mar 17, 2010
- Messages
- 964
made it from copper sheet, 3 pieces of 1/8 sheet copper soldered together 2 by 7 inches. Each side was individually tinned the whole side then heated together to join.
tapped 6 holes for bolt studs
Then I created a 14 inch wire, used nibco copper pipe reducers for the ends, smashed fit with hammer with copper wire inside and soldered sealed the ends
I covered the wire with 5/8 rubber heater hose.
The copper strands were from an old jumper cable plus some 8 gauge multistrand wire laying around.
made a wood block sealed with polyurethane and also the backside of the copper bus bar.
I needed a distribution expansion point for the inverter wiring as the single stud coming from the 4 way battery switch was insufficient space wise.
I imagine the wire is similar to a 4/0 wire.
I put up some pics to show you.
so now instead of 6 wires coming right off the switch post, the idea is to run that single wire to the bus and hook it all up there. Starters, house wires, inverter positive , raritan lectrasan toilet,
