Were flying splices ever legal?
In the second picture, is that an al to cu splice? The entrance facility can be al, but I didn't think you could do anything with it but connect to the panel. I could be wrong, I'm an accountant by education and master of nothing by training.
Look carefully at the upper left neutral!
There's at least 2 things wrong in this picture, can you name them?
I cant quite tell whats up with the neutral other than its cut?
Copper to aluminum under same lug and the copper isnt even a manufactured conductor
Poster child as to why we have electrical codes
We bought a lake house a few years ago that I knew I wanted to rewire the living room since it didnt have grounded plugs. Just a pet peeve of mine. I started opening up the walls to do some remodeling and noticed that almost every wall had a splice in it. Kicker was most were done with duct tape and left hanging, some were just twisted and left nothing covering the hot wires.
About 2 days into it I said F it and gutted the entire house. Found 20+ splices. It now has all new electric ran from the panel through out the house. I dont understand how the house didn't burn down.
In regard to splices.. if they are done correctly.. what issues would they cause?
A lot of the NEC, and rightly so, is to prevent techniques that could be an issue if not well thought out and not well implemented.
I'm not saying don't follow the NEC, I am asking the electricians here that make a living doing this, what is the issue?
A correctly soldered splice with correct insulation after the splice is made, what's the issue from a practical standpoint, not a code standpoint?
These were working, not sure how much load was on them and the fact it was on 15A didn't hurt but,,, these were twisted and taped and not very well at that. A few had wire nuts on them. A twisted splice doesn't have the pressure connection a nut gives it. Even a couple of the nuts were loose, looks like they pre twist them which would have been ok provided the nut was tight.In regard to splices.. if they are done correctly.. what issues would they cause?
People seem to forget the code is a minimum, not always the best way.
Most are familiar with the clear round plastic containers that 3M electrical tape comes in. At the public school where I worked new parking lot lights installed as part of a recent capital project stopped working. We opened a grade level junction box and the contractors used one of those 3M tape containers, cut holes in the side and made their junctions in it and then wrapped it with electrical tape. They were union electricians doing public work for prevailing wages, not some guys from outside Home Depot.
