CREE 950 Lumen LED light $10
WilltheEngineer
Central, FL
I'm not for sure about the 950 Lumen rating, but for $9.97 + $3 shipping, it looks like a good back-up vehicle or utility hand light.
http://www.yugster.com/deals/51751-cree-xm-t6-8w-950lm-3-mode-focus-flashlight-torch-black
Specifications:
Model: SS - A100
Emitter Type: CREE / XM - T6
Brightness: 950 Lumens
Power: 8W
Bulb Quantity: 1
Light Color: White
LED Lifespan: 100, 000 hours
Modes: 3
Mode Arrangement: Hi > Lo > Strobe
Lighting Distance: 500 m
Battery Configuration: 1 x 18650 or 3 x AA batteries - GRAB SOME
Input Voltage: 3.6 - 4.2V
Runtime: 2 - 4 hours
Switch Type: Clicky / Clickie
Switch Location: Tail - cap
Lens: Convex Lens
Special Features: Zoomable
Material: Aluminum
Color: Black
Dimensions: 5.31" x 1.37" x 1.10" / (13.5 x 3.5 x 2.8) cm (L x Head Dia.x Body Dia.)
Weight 162g / 5.71oz
30 Day Yugster Warranty
Read more at http://www.yugster.com/deals/51751-...us-flashlight-torch-black#Di6BPVcXpm5eMdJC.99
Vegaman_Dan
Pacific, WA
There's a bunch of variations of this light out for CREE and they are all decent. Matters mostly if you want rechargeable or case design. They are all bright as hell single square LED lights with focus rings and strobe/flash feature.
W
WilltheEngineer
Central, FL
Fiendfx, they take awhile to ship. Last time I ordered Snap-On gloves from them, I think it was a week before they shipped.
+1 on what Vegaman stated, the two posted here, are different. But a different one that I have is very bright, but not the claimed lumens.
FiendFX
California
Is the light shines out white bright or white with blueish tint ? Do they even give a tracking number?
FiendFX
California
Specifications:
Model: SS - A100
Power: 8W
Bulb Quantity: 1
Light Color: White
Modes: 3
Lens: Convex Lens
Material: Aluminum
Color: Black
Did they give you a tracking number? I checked my account and they have not even shipped it yet.
Jack Olsen
Los Angeles
I got the one linked on Amazon last week. Listed as 1600 lumen. Hah. It might be 100-150 lumens, maybe less. Still, it's a decent light for the price. The one I got has five modes (bright/med/dim/strobe/SOS), but you turn it on you, get bright, and then you turn it off.
FiendFX
California
Just an update, 3 weeks later, I finally received the light. I must say I'm impressed of the output. Although I did buy one from ebay almost identical, but the light has a blue-ish tint vs the one on yugster it's bright white which is a plus. It's actually brighter.
Hustler388
wonder why it take so long to ship?
So whats next 2000 lumens for $10.99
sux they dont have some way to regulate the CLAIMS
Still cheap light:D
djb2
Redwood forests
Those specs are not credible.
If it's powered by a single 18650 cell, it won't last 2-4 hours while drawing 8W.
And 8W isn't quite enough power to put out 950 lumens
A typical 18650 lithium battery might have 8 watt-hours of power. (It probably will have significantly less if discharged in an hour or two, but we'll be optimistic.) If they are actually getting 2 hours, they are only drawing 4 watts or less.
Edit: The datasheet for the XM-L LEDs lists the T6 as a nominal 280 lumen emitter when run at 700mA, with a calculated value of 325% brighter when run at the limit of 3A @ 3.35V. So it might produce 950 lumens just before it burns out, but it's not going to happen in this flashlight. That said, this could still be an great light for the price.
mnster
Rockford, IL
Got mine yesterday. Its really bright I'd guess 200-300 lumens. Almost to bright on the high setting to be useful for close up mechanic work do to so much glare off the part. Overall build quality seems great so far very impressed for the money I spent. I bought it with the offered batteries and charger. Run time seems really good so far. Compares well to the lights I've spent $40 or more on. I certainly love the wide beam spread for under vehicle work. Time will tell how it holds up.
W
WilltheEngineer
Central, FL
GJ-ers,
Sorry for missing out on the reply posts, I've been working crazy hrs with the GOV shutdown, etc...
-On CREE, from my experience, they make a lot of items (some are sold in big box stores), but they have also subcontracted items out in the past. I would guess any cheap priced item, would be subcontracted.
-On Lumens, with any cheap priced light, like I stated in the org post, I wouldn't believe the lumens rating. A lot of factors can vary for what we humans consider levels of brightness. Color temp, refraction, emissivity, blaa, blaa, and we turn this post into a small science project...
But it's bright...for ~$10 If you require a certain level of lumens, then I'd suggest going to a local store, or order a spec light you know is the correct lumens rating.
I like mine, and kind of wished I ordered two...and consider it a Hot Deal
-Yugster shipping, I've only ordered 2 items from them, and both didn't ship for a week. I wasn't in a rush, so no issue. If you are in a rush, you may want to try amazon prime.
Hope this helps....and if someone post the item again, I would recommend it for a nice little bright light.
W
WilltheEngineer
Central, FL
Looks like a larger version was just posted on Yugster. Again, the lumens are usually not correct, and Yugster takes awhile to ship (~about a week before shipped).
Features:
Portable, easy to carry and store
Slender handle is comfortable
High quality Aluminum Alloy construction
Wide beam is ideal for lighting broad paths and deep darkness
High brightness makes it suitable for camping, travel, outdoor activities, etc.
Requires 2 x 18650 batteries (not included)
5 Modes: Hi - Mid - Lo - Strobe - SOS
Button-activated
1600 Lumens
Read more at http://www.yugster.com/#whsasSpphbE3mjT4.99
jhall0712
Get this one from Amazon and don't think twice. Hell, buy 20 like I did and pass them out. They are unbelievable for the price. Single AA battery.
If you wan't a bit brighter and heaver, buy this one. It's not 1000 lumens as stated but it's crazy bright.
Both are shipped from China so expect at least a three week wait.
Hustler388
I received mine today,ordered September 30, 2013,I got 3 for $21.54, i was surprised it is pretty bright and the beam is adjustable, pencil beam is square, then goes wide beam kinda like a flood.it was worth it to me.
shipped direct from japan,tiwan whatever
Its pretty close to my surefire 200lum
Rob:D
FiendFX
California
Rob:D
How did you get 3 for 21$? It's 10$/ flashlight
Bsj04
Aledo, TX
Rob:D
I ordered 3 also on the 1st of oct, Hopefully they will be here soon. I've been looking for them in the mail.
Hustler388
i guess i got the amazon one ,,,,1600LM Lumen Zoomable CREE XML XM-L T6 LED Flashlight Torch
heres some picks
see the dental pick this was loose on one, had to screw back together,guess the plane vibrated,lol
it has a sq bulk, when in wide angle its wide
Hustler388
here a comparison with my 160.00 surefire, this was only a garage wall test
also the coleman 500lum, socaled,
the last one is from a lowes $9.99 10 pack of leds from 2 years ago with the same battery's,:shocking:
Hustler388
light off in garage last one zoomed out
lined up
sure fire 160. 200 lum
surefire d2 70.ish 200 lum
colemean 500 lum
walter 12.00
Cree $7.ish 1600 lums
FiendFX
California
I wonder which one is brighter, your sunfire or the stream light stinger c4 LED flashlight. Because they are about the same price.
beamrider
Columbus OH (displaced from Wheeling)
I really doubt any of these "junker" lights have an accurate lumen rating. I've got a Cree XML T-6 that was advertised at 1000 lumens. Runs on 1x18650, but same LED. For the 10bux I paid for it, it's well worth it, and if it was single mode instead of 5 mode, I'd buy 10 more and stash them everywhere. Insane brightness for what I paid.
Code:
http://www.fasttech.com/products/1206400
beamrider
cree is more a manufacturer of LED modules, a lot of makers (ultrafire, trustfire, etc) just make the housing and get the module from cree.
it's pretty amazing to me, 10 years ago, to get that much light output, I'd need a 6D maglite with a xenon bulb.....lol
