crescent lifetime ratchets.
ears
lorton VA
These are 1/2 in drive 48 tooth crescent lifetime ratchets. Three slight variations. I played around with them a little at work opened them up stuck some grease in them put them back together then sprayed them with pb to thin out the grease a little. They all work perfectly, nice ratchets. $15 apiece shipped. ALL SOLD/PENDING
Ratchet 1 appears unused it is a cs70 the head is a bit thinner on this one and it uses a circular spring clip to hold in the guts. It is a patent pending the patent was issued in 1961.
Numbers 2,3,and 5 are identical. Crescent logo marked lifetime ls70. Number 5appears unused. 2 and 3 have a little chrome wear on the head but not bad. The dirt in the handle is just that dirt. Waste oil heater went out and it was too cold for me to get into the parts washer today.
Number 4 appears unused it is identical to 2,3,5 but labeled crescent ls70.
lbgradwell
Oakville, ON
I'll take number 1 if snaparxon doesn't.
If he does take number 1, I'll take number 3 if it's the only one left.
PM sent...
MOPARHOUND!
Kansas City
Late to this party, but I'll get in line if any deals fall through.
Have a couple of examples in the ratchet graveyard, both broken. Would like a couple that function.
rhastings80
Got mine today. Very nice ratchet and very smooth.
A word of caution if you take it apart be careful as on mine a spring came flying out luckily I found it. Very cool ratchet.
Thanks!
