I got this ratchet with the Mac V5R I autopsied a few weeks back. I don't know this brand, but it appears to be a decent quality tool that you might find at an auto parts store, Kmart or other. On the top it Says "Crew Line" on the back it says "Boxer" and made in Taiwan.
View media item 11230
The rat is a bit unique in the position of the selector. It's the black switch in the middle of the handle. The switch is positioned well, so that the thumb rests on it and can quickly change direction. The head has the quick release feature we've all seen.
View media item 11231
The body is plastic, with two steel inserts for the top and bottom. It is held together with three Torx screws.
View media item 11233
These are all of the internal parts. The body, selector switch and the selector pawl are plastic, the rest is metal.
View media item 11237
View media item 11234
The metal strip resting on the pawl slips into a slit in the pawl and a slit in another pawl on the selector. That's the plastic part on the right. When you slide the selector up/back, the metal flexes and changes the pawl direction. The plastic part on the right slips over the tang on the selector (part in the center).
There was a little fumbling involved getting the rat back together. Now that I've assembled it, I wouldn't have as much trouble a second time.
View media item 11232
The action and the selector are pretty smooth. Overall, a decent import rat for light work.
