Crimping battery cable tool
Slednut
Washington state
I just used this one to wire the battery in the trunk project car. It's on the expensive side and is tough to use in tight places.
It does a lot of different size cable though.
I also like using lugs that can be crimped twice.
csp
Franktown, CO
Second, yes, the real problem is entirely a metric vs AWG size issue. Too many people here don't seem to understand what a crimp is and how it works.
Regardless of this, your earlier suggestion to look up a conversion chart isn't really of any use. Knowing that 2AWG converts to 33.6 mm squared doesn't help anyone select the correct die to use instead of the one marked 2AWG.
rlitman
Long Island
Not sure what you mean. None of the dies on my two Chinese hydraulic crimpers say AWG anywhere, because they're not marked in AWG. And if they are marked in AWG, I wouldn't blindly trust the markings anyway, because they are positively made to mm-sq sizes.
To put it a different way, would you feel comfortable taking a ruler scribed in centimeters, where 2cm was marked as 1", because that's the sort of thing going on here?
csp
Franktown, CO
Mine are marked AWG. The point was that they are not marked in MM squared, so looking up a conversion chart is useless when there's certainly no reference to MM squared on the dies, whether the markings include the letters AWG or not.
It's a game of trial and error to get the correct sized die.
rlitman
Long Island
I guess that's the HF version. Yeah, it's going to be trial and error. When I figured out which ones were right, I marked my dies.
astroracer
Mid_Michigan
Hmm, I like your idea! I may make another adapter like yours. A piece of angle would work great and make the tool easier to clamp in a vise.
Take your mount and transfer the holes to the working end like I did. Having the dies fully accessible during crimping is very nice. It is easy to see what is going on to better control the crimp. :)
Mark
oldwino
Sonoma County California (wine country)
Mark
Gee, Mark, between the two of us we must be genus’s :bounce::bounce:
csp
Franktown, CO
One idea I had on the crimping dies is to modify the little ones that don't get used. Who would use one of these for anything smaller than AWG 6 or 8 anyhow?
I'm going to mark a couple with the dimensions of a known size hex nut that looks like the approximate size of a crimped connector, lets say 0 for example. Once marked, machine out the material needed to get to that known size and give it a try. The steel is fairly hard, based on unscientific testing with a file.
It can't be any worse than the guessing with the current markings, and the fact that the largest connector mine will crimp correctly with the current one marked "0" is AWG 4. That is the largest die in my set. Luckily I only gave $20 in an online tool auction and it was still an unopened box. No big loss if it doesn't work.
