I realize that as I type this, that a picture would probably be helpful, so maybe I'll add one later, but I think you can visualize what I am saying.
Also, I already build 7 cabinets this way, so it's a little late to be asking this, but I plan to build more.
I built several wall cabinets following this plan:
1. Use 3/4" mdf for all sides, including full back (maybe overkill for the back, but I can add mounting screws anywhere this way.
2. Cut 3/4" dadoes, 1/4" deep, 1.5 inches from top, bottom, and back (making the back of cabinet 3/4" from wall, except on edges.
3. Cut the same dado on the back panel, so the top and bottom shelves sit in a dado on all sides.
4. Glue/screw/nail all pieces together.
5. Face frame is the standard primed fj pine at big box stores, top rail is 2.5, sides and bottom are 1.5", which makes the bottom of ff flush with bottom (shelf) of cabinet, and flush with bottom of sides considering the dado ends 1.5" from bottom/top. 3/4" overhang on sides, 1 3/4" on top.
My doubt comes into play when I consider the added benefit of a full thickness back panel, and if I am losing too much interior space by cutting the dado where I do. I lose 1.5" of depth on a 12" cabinet. I did this to account for any evenness in the walls, but I may have gone overboard. I could cut a rabbet on the back of the cabinet and use only 1/2" material, and gain an inch.
Also, since these cabinets are 12" x 24" shop cabinets, I don't put any shelves in them, but I think I may add some later.
