Garage size: 16' x 20' (1.5 car attached garage), ceilings 9.5'
14' wide OHD with windows.
I have just insulated all the walls and ran new electrical in the garage so I am now looking to upgrade the lighting since there is currently just the builders lights (2x single halogen bulb fixtures). I use the garage mostly for working on my cars and lately for some carpentry/house renos. The garage is quite small so the current lights fill the garage pretty well but the problem is they are right in the middle so if I have a car in the garage with the hood open, the hood blocks the light from the front of the car.
My plan is to add 4x T8 light fixtures in the main area of the garage and then 2x T8 light fixtures near the far end where my bench is and to not create shadows if I have a car hood open. I plan to run them on 3 separate switches (see attached diagram) so that I can turn them on selectively. I also plan to leave the current single bulb halogen fixtures to use when I only need to quickly pop into the garage to grab something (don't need to turn the tubes on).
Will this be to bright for the size of my garage? Should I just add more single bulb fixtures? The current single fixtures have 42 watt CFLs (200 watt equivalent).
Diagram:
Green boxes = 120V and 240V outlets
Cyan boxes = T8 fixtures, 4ft with 2 lamps ea.
Yellow boxes = single bulb halogen fixtures
Blue box = outline of car
Thanks!
Adam
Diagram:
Thanks!
Adam
