Crow foot, again
rhp
Having studied the previous thread on crowsfeet, (& admired Uncle Buck's tools) I have a simple question:
A bolt should rotate on a thread, but logically attaching a crows foot to a ratchet make the center of rotation the slot rather than the bolt. Empirically, attaching a ratchet should turn the crows foot at right angles rather than a 360 smooth arc, since the center of rotation is the square attachment slot.
1) Am I missing something?, & (2) if not, are there drive rings available to drive an off-center attachment, such as a crowsfoot in a smooth rotational 360 arc?
Thanks, RHP
DetroitDIESEL444
think of them as extreme offset wrenches.
Its not something you use very often but when you need them they are life savers.
garfunkle24
Saskatoon, Canada
Voila:
http://buy1.snapon.com/catalog/item.asp?search=true&item_ID=63264&PartNo=m3503b&group_id=1311&supersede=&store=snapon-store&tool=all
Have seen others before, often lumped in the 'distributor wrenches' category.
BTW, besides this specific application, when would you ever need the setup you describe? ie a socket wouldn't fit
