Crowfoot vs flare nut crowfoot
hairtrigger
I was wondering, why would you need a regular crowfoot socket set if you already have a flare nut crowfoot socket set? I mean, wherever you would want to use a crowfoot like on a stud or turnbuckle (jam nut etc) you would be able to slide a flare nut crowfoot onto it. So why two sets? Is there something that the normal crowfoot set is better suited for?
xj31
I would say its for ease of use. Same as a wrench. I use a crowfoot when I need it, but an open end is usually easier to put on and take off a fastener.
And I have them all. Crowfoot, open end, standard and metric.
H
hairtrigger
But what I'm saying is, I already have the flare nut crowsfoot sockets. Why would I need to get a regular set? Is there anything they are better suited to do? I use my flare nut crowfoot sets for torquing tie rods jam nuts. Works fine.
crewchief888
NW indiana
all depends on what you're working on.
if you havent found a use for an open end crowsfoot, you probably dont need them.
i have a couple flare nut crowsfeet, bought them for a particularly PITA hyd tubeline/ hose on a dozer that was slightly beyond my reach. i could get to it with a crowsfoot, and 36" extension, or pull the ROPS and fuel tank.
i had already started to round off one tubeline nut, so i got a couple flarenut crowsfeet to do the job.
i use open ended crowsfeet on a lot of hyd hose and tubes, that could be considered "inaccessable" by any other means.
:beer:
xj31
I know what you are saying and I agree. You don't need to get anything. I have a lot of tools I don't need. I just know the open ends are easier to use on stuff that they don't slip on. They just speed things up for me. By your logic, I would assume that you don't have any open end wrenches either. You don't need those, right?
plinker
Northern Wi
The main difference is the open end crowfoot is straight vs the flarenut crowfoot is slightly off set. It can be helpful to have both.
H
hairtrigger
I don't have any flare nut wrenches, only open ended. I only work on suspensions (no brake lines as of yet), just struts, tie rods, ball joints, trailing arms. Up north you can find a lot of people that have bad suspension parts because the roads **** and the chemicals they put down eat stuff up pretty bad.
But I bought the flare nut sockets because they were cheaper than the open ended crowsfoot sockets, and more complete. Doesn't make any sense. But if I don't really need them I don't need them. Just don't wanna run into some situation where I DO need them and gotta run to the store and **** out $50 to $80 on a set of open ended crowfoots.
H
hairtrigger
:beer:
Never thought of using one on an extension to get at something. Great idea though.
kruegdr
Kansas
Theyve saved my **** on a lot of brake fittings where normal brake wrenches couldn't reach or I couldn't get enough torque to them. I haven't had a need for the non-crowsfoot, and the crowsfoot that I do have have served well. Just picked up the northern tool set of english ones with a gift card. I've had a KD USA metric set that I got from Cripe which was great.
diesel research
gulf coast, TEXAS
:headscrat
tat is one of their MAIN purposes. Combine a wide variety of "connectors" extensions, flex and or indexing ratchets to create funky shaped wrenches to reach hard to reach places.
A crowfoot won't always fit over a threaded rod to access some jamnuts.
If someone says "you don't need ___ tool" as an overall blanket statement, chances are they simply do not have enough experience to encounter such a situation. Sometimes it just takes longer than average human lifespan to find the use. That is not the case with open end crowfeet though.
I have encountered multiple different types of fasteners that a box end/socket/flarenut would not fit on. That leaves you with options like pipe wrench, adjustable, open ends, or ratcheting split wrenches.
Old Donn
The fill plug on my old Chevy's differential is an 11/16" square head with a collar around it. The only way to get at it is with either a double square socket or an 11/16" crowfoot. Doubt a flare would work on a square head, but I never tried it either.
4x4gearhead
New Hampshire
I use regular open end crows feet for hydraulic lines, a lot of times the flare nut style open end wont fit over the collar of a straight hose crimp/hose.
