Crows feet
Jlarson
I keep a lot of cheap ones around too cause I'll put em on an impact and extension and rattle a stubborn fitting till it gives up. A long air hammer bit is also useful in that area.
Renegade1LI
long island ny
It ***** if you need them & don't have them, when we did more of our own heavy equipment repair they saw a lot of use, now not so much. For some reason when these big machines are designed servicing them wasn't a priority, I also used them removing some car transmissions.
Neggy
I used my SAE crows feet from 198X last year when rebuilding the top end of my 2013 Harley.... I can't even remember when the last time I used them before that. Snap-On crowsfeet too
My Metric ones.... can't remember the last time I used them
But back in the day there were times they were worth their weight in latinum
I bought a serpentine belt tool a few years back and it had a few cheap Metric crows feet in the kit.
Steve_P
This is one tool where it's Snap-On or bust.
My two sets are vintage KD USA and are fine. At that time it was the same as Craftsman USA. But if buying today, you might be correct. If I was buying today, I would also look at SK
Old Donn
Not a pro either. Picked up Craftsman fractional and metric crows feet some years back because some day, I thought I might need them. Not yet so far, but they're at the ready.
Bigblue&Goldie
Mine are KD also. I think I'd go Tekton if I was to buy new (as an infrequent user).
cannuck
Rural SK
I have the usual metric and US open and Weatherhead, but on top of that some really large ones from an inch up to 3 or so. Actually use the big ones a fair bit (inside of power transformers when there is no room to swing a wrench on bushing jamb nuts. I will be making an even larger one later this month - once more for a bushing nut that is too close to others, core and wall to be able to turn a long (and very thin) flat wrench (laser cut from plate, 1/2 drive square end cut from an impact socket and welded on).
AirMech#406
Line wrenches would be #2 on that list.
I gotta disagree. I have used S/O, Mac, Proto, Craftsman... I never really had a situation where I found myself saying "whew! lucky thing we had these Snap-Ons or that would have been impossible!" I actually sold my S/O set in favor of the lower-profile Tekton crows feet. I have no regrets. You don't need to fork over an absurd amount of money to tighten AN fittings and hard-to-reach fasteners.
As to the OPs question: as others have already said, they are invaluable for torquing hydraulic fittings and fasteners that are difficult to reach with a regular wrench or socket. They are heavily utilized in aviation, both commercial and general.
CoconutPete
Charlotte, NC & Denmark
I have a 20 year old BMW Z3 that's my Sunday car.
I finally broke down and bought a set when replacing the clutch line. There was just no way to get a wrench around the nut up between the wall of the transmission tunnel and the transmission itself.
Full disclosure: I went for the cheap HarborFreigh set and i did have to go to work on the 13MM one with a file in order for my ratchet extension to actually fit.....
iagsxr
Vinton, Iowa
Replaced most of the hydraulic hoses on my forklift last summer. There were several fittings that you had to use a crow's foot.
Got in my dad's box and used his as I don't own a set. After that was all fired up to get my own till I thought about it a little bit and realized that was the first time I'd needed them since we closed our shop a little over ten years ago.
If I had my own set they'd get used more often, but most of the time there's a workaround.
