Crowsfoot or other for this nut?
noid
Immediately to the right and above is a metal heat shield. Though possible to remove the heatshield, it would require more disassembly not pictured that I would rather avoid.
Nut is attached to a balljoint, so no option to counter hold the nut and unscrew from below.
I was thinking a crowsfoot, but at this angle I’d need a swivel and a crowsfoot - that setup would push upward almost as much as it would apply counterclockwise torque.
Thoughts?
NUTTSGT
Northern Central Ohio
Since you are debating how to do it, the very first thing I would so is go out there and spray it with some WD, Liquid Wrench, PB Blaster, Kroil or whatever you have on hand. Letting it soak a day or two will increase you chances of it coming off without busting a knuckle.
It's really hard to imagine what will work as a picture isn't 3D. Swivel with short socket, flexhead wrench, crows foot, wrench with an extender ? All viable options.
cmandp
New Jersey
Nut holding the taper on a Balljoint? Those are usually fairly large thread and thus higher torque.
I like to use an impact because they often like to spin the stud once you loosen them enough. Sometimes disassembly is easier then trying to find a clever way to turn things in situ.
