markle10471
- Joined
- Oct 8, 2023
- Messages
- 2
Anyone no how long I would need to wait before putting CS-309 concrete sealer on freshly poured concrete?
CS-309 is an acrylic curing sealer. If you read the data sheets, it states that it can be applied as soon as excess water has evaporated from the surface and you can walk on the concrete without marring it. You didn't state if you were using CS-309-25 or CS-309-30, so make sure you read up on the one you are using.Anyone no how long I would need to wait before putting CS-309 concrete sealer on freshly poured concrete?
www.wrmeadows.com
www.wrmeadows.com
Shea,CS-309 is an acrylic curing sealer. If you read the data sheets, it states that it can be applied as soon as excess water has evaporated from the surface and you can walk on the concrete without marring it. You didn't state if you were using CS-309-25 or CS-309-30, so make sure you read up on the one you are using.
CS-309-25
CS-309-25 Acrylic Curing and Sealing Compound from W. R. Meadows provides a premium-grade film for optimum moisture retention, and produces a hard, dense, high compressive strength concrete.www.wrmeadows.com
CS-309-30
CS-309-30 acrylic curing and sealing compound is a high solids, clear, transparent, ready-to-apply, non-yellowing, liquid membrane-forming compound formulated from special acrylic polymers and quick-evaporating solvents that effectively cures and seals freshly placed concrete. Once properly...www.wrmeadows.com
