knudsen
New hoist.
I used it to lift itself up:
Then mounted it under my wood loft on some 1/4" hooks:
Now I can lift the mill, so I can properly reinforce the bench work and get it bolted down. I put that off for years after the experience of lifting it onto the bench by hand. My voice is still and octave higher and unmentionable body parts are gone.
Next I'll make a cradle to mount it from the rafters and allow it to roll around a bit. I didn't lift the mill yet, as I need to bore some holes in it to accommodate a lifting point, but I did a test lift on my 55 lb anvil. Nice! I'm doing the double line pull to run it slower. Power won't be a problem, it should be able to pull my rafters down...
I had a buick V6 hung off two 2 X 6 rafters and it held, but was scary!!!
