Curious switch meltdown
Codyboy
S.E. TEXAS
No. The switch is always on and controls an exterior outlet for the dusk-to-dawn 5 hr LED pathway lights. It was odd to find a straight undamaged single wire that supplies power to a garage outlet 25-30 ft away which I discovered was no longer attached most likely back stabbed.
The "switch" did not fail apparently.
What failed was the connections at the switch.
Loose over time.
Car charger gets a pigtail and landscape lights feed through a new switch.
M
mrvm
PA
Thank you everyone for your analysis and information. I am fortunate to discover the hot plastic wall plate then to inspect behind the plate. Some people are not that fortunate to discover a potential fire risk before it’s too late. I hope others can benefit from this thread.
gtae07
Fayetteville, GA
A high resistance connection does not trip a breaker. A short circuit or something drawing excessive current, like a short circuit, trip a breaker.
I know. I'm saying, I'm amazed that all the stuff they had plugged into the circuit never tripped it by drawing too much current at once.
