Current Craftsman Sockets
N_Jay
Anyone notice current Craftsman sockets don't have nice square and true drive sides?
It looks like they are purposely designed not to take excessive forces without starting to round the drive end.
Maybe it was done so they can deny warranty coverage if an impact driver is used?
finn
The UP, God's country
Sounds like you’re describing flank drive sockets, which move the contact point away from the high stress corner location.
That design has become common across the industry, as far as I can tell. I think it was pioneered by SnapOn or one of the other Premium brands.
milky2k
Los Angeles CA
Can you provide a picture to see what you are talking about? If you are talking about Flank drive AKA off corner engagement then just about every socket made in the past 20 years or so have this feature.
908Jim
OP is talking about the square end, not the hex side
See above. Looks like OP is talking about the square drive side, not the hex side.
I think current craftsman sockets are actually quite nice. I'll go so far as to say nicer than Tekton and they can be purchased at a good price with sales from Ace or Lowes. I purchased Metric deeps and shallows 4-14mm for around $30 total with an ace sale and they have held up well. I even use them with my 1/4 air ratchet. (yes, I still use an air ratchet. Way more compact than cordless)
N
N_Jay
I know about flank drive but usually I see it on the socket side.
Maybe my tinfoil hat is a bit tight, but these seem to have quite a bit of "relief" in the corners, and only a small flat in the flank because the cut for the retention ball runs nearly the full depth with only a small section retained.
Next time I am at my shop, I will grab some pictures.
finn
Square is always weaker than contoured. The sharp corner of a square feature is a stress riser.
Doesn’t matter which end the sharp corner is on, it’s still a stress riser.
Look up notch effect.
N
N_Jay
I understand, but between the (in my opinion) overly wide corner relief, and the removal of much of the center flat, the remaining material seems minimal.
I noticed it on my 19mm deep, as I have a couple of cars with lug torques over 100 Ft-Lbs
Photos to follow.
Hakeem
Chicago
I’ve seen sockets with the drive end relieved. Makes you wonder why some do it and some don’t.
Either way - unless your sockets are truly defective, I’d expect them to hold up just fine
woody 73
The Great State Up North
Old post of mine, hope you enjoy it:
