Curtis e-50 air compressor econoline
ManOnTheCouch
What would an old one in working condition be worth? I know Curtis is a great name in air compressors. There's an old "econo line" 80 gallon that I know is for sale in working condition. Here's a pic of a similar one at this link.
https://www.purplewave.com/auction/121031A/item/M9008
Anything I should check for if I go to look at it? How long should it take from empty to full if working within specs etc?
wanderer
I can’t believe that one brought 1100 bucks. I would be thinking $500 max if it’s single phase and even less if it is three phase. don’t think you can get parts for a Curtis, I’d look at it as three components, tank, motor, pump. Tank is probably worth 200 max, motor a few hundred if it’s single phase, pump up to a few hundred as well.
ManOnTheCouch
Parts are all still available. It's single phase with a Baldor motor. Pump is two stage rated for 17.4 cfm and max 175 psi. I think I might pull the trigger on it at $400
Brand X
Disc valve pump. Super reliable . I had mine compressor for about 21 years,and not one issue. Bought it from Pacific air in Portland .The Curtis Master-line was a step above, but the low rent E-50 pumps is still one heck of a quality pump. All parts are available for it, but probably will not need them, if ran with a quality Syn oil from the start.. New **** is not even in the same ballpark.
ManOnTheCouch
So, I bought it. It runs like a top, and I can’t believe how quiet it is. It runs at a very low rpm compared to many of the newer compressors. Prior to buying it, I tested it by running from empty to when the pressure switch shut it off at 155 psi. It took just over 6 1/2 minutes to fill the 80 gallon tank. I’m impressed.
Now for an oil change. Any recommendations on oil?
Also, I plan to repaint it just so it looks better. Any suggestions on what paint to use?
ManOnTheCouch
Quick update.
I painted this Ford tractor blue with Rustoleum hammered silver accents.
sberry
Brethren, Michigan
Nice, good color, well worth a shot of paint. As for oil one of the synthetics would be good for life of the unit.
