Custom Boxes
TheToolEnthusiast
New England
I’m wondering if anybody has a vendor recommendation for custom sized paperboard boxes? Looking to get some blank boxes made for screw storage for an older wall mounted organizer.
kettch
My wife manufactures and ships products in lots of different size boxes for her business, and I've been down this rabbit hole. Truly custom boxes will cost you an arm and a leg for a one-off project. There are thousands of vendors out there, and they've all got lots of options, so you might not need to go the custom route. Do you have a picture of what you're after? Sometimes you can match up with something on Uline, or another commercial supply house, and get a good deal.
willy3486
Middle Tennessee
Uline has a lot of boxes and such. Years ago I got some used cardboard boxes that just folded from one sheet of cardboard. I took one and traced it out on a piece of scrap plywood. I think I made it smaller to fit my shelves as well, just traced one side,slid it down to give me a 12 inch bottom instead of 16 inches. Then I took a bunch of boxes stuff came in and cut it into blanks. I traced the plywood form onto the top one. Where the hole was made to fold the tab in I put a bolt through about 15 sheets of cardboard and trimmed them all together on a bandsaw. They did fine. One thing about cardboard is after using them for years they get old and start degrading. I got tired of pulling the boxes and being carefull to make sure they didn't fall apart. I went ahead in the last year and bought a few hundred of the arko plastic bins and replaced all the cardboard bins. I am glad I did.
The Cobbler
yes, custom paperbox will be $$$ , if you can even find someone to quote you on small quantities.
I'm sure you can find close matches by shopping around . May want to look at other options as well like mentioned above
slowtwitch73
Hellgate
"easy to assemble cardboard boxes"
There are others as well...
