custom computer for sale
ozzy214
https://t.me/pump_upp
I have a custom computer built by myself for sale. It needs to be repaired though. What happened is the ram went bad. Lifetime guarantee so they can be replaced easily. I just need the money for rent since I'm screwed with no work. So asking 250 cash or best offer. Located in Dunmore, Pa or can ship.
Its a antec 900 gamer case, asus p5q se motherboard, e6300 proc oc to 2.6 stable. 8800 gt vid card. 2 x 1 gig pc6200 ballistix tracer ram. antec neo power modular 500 w psu
System is bad *** and runs windows 7 64 bit no issue. I had plans to get a 2 x 2gig ram set, but with my layoff that got put on hold. I wasn't going to rma the old ram due to this and the fact I wanted more gigs for 64 bit windows 7.
So basically system is complete and will boot right up. But the ram has errors tested by memtest. So eventually the os will crash after a bit.
Motherboard was bought this xmas for 100 cash. Proc and vid card is older. Only other issue is vid card has ghetto cooler devised by me as it was heating up too much with stock cooler. And last issue is plexiglass side is cracked.
I don't have pics ATM due to cant find the camera, but will post if needed. For 250 cash this a smoking deal. Board alone was 100 in December. A year ago I paid 150 for the case, 200 for the vid card, and 85 for the ram. The proc was a rescue, so free.
Only thing not included is a hard drive due to personal information. So this is good for someone who has new ram or wants to rma the old stuff.
Also considering offers...
DaMaN
Rahway, NJ
Can you send me pics of the case, tell me if the vid card still has the stock cooler with it and if crucial will still rma ballistix ram. Do you have all the items the motherboard came with? Do you have the actual Intel box and heatsink for the processor?
O
ozzy214
I can pics up later on no issue. To answer your questions. Pic will reflect this. The vid card actually has the stock cooler on it, but I removed the outer metal part of the shroud and wire tied a 80 mm fan to it. Drop temps down to 54c or less at idle from 65c stock.
As far as mobo box I can look, but I think its gone. I recently moved and think it went in the trash. But the mobo is still under warranty. I can throw in some accessories like ide cable, sata cables, etc. But they didn't really give much with the board. I should also be able to find the manual.
And as far as the cpu box, no good. It was a reclaimed from a dell xps system that was trashed I got off of craigslist. The chip is pretty good. Had it in 2 different boards and oc the whole time from stock 1.8 speed to current 2.6 on air 24/7 use.
Btw. Forgot to mention. No longer have the stock cooler. Due to the issues with the stupid plastic push pins Intel designed for the stock cooler and the low flow, I do have a Asus cooler on the cpu. Not the best and sounds like a jet on high, but on slower fan speeds it kept the cpu nice and chill at 40c 24/7 use.
Hope this answers your questions and I will get a pic up shortly.
Pics as promised and forget, yes Crucial will RMA the ram no issue. In fact they will give you the newer chip version that uses less juice for higher overclocks. I already had a rma to do it, But was out of town too long. They only give like 15 days to get it to them and I missed the deadline. So I said the hell with it and was going to buy a bigger set as I said with higher clocks no less. But the economy took and a dump and here I am trying to make rent money to sell my baby. Used to Play crysis warhead and hellgate london at 8 hrs a stretch with no issue with good fps with this.
