Custom Discharge Tube
StangStang
Hey All,
I am having a hard time finding the info I need so I apologize in advance if this was already covered.
I made the mistake of running braided line from my compressor head to my aftercooler. Eventually I noticed that the compressor was running longer and longer. The rubber inside the line hardened and cracked, leaking air (lasted 10 months).
So, I want to replace with a copper tube / pipe.
Question: I need 1/2" outer diameter copper tube / pipe. What should I use? I have read soft and hard, type M and L. I need to know what exactly I need to buy in regards to copper. "Plumber" at Home Depot said you can't bend copper pipe so I am a bit confused. I see that I can buy a roll of tube or purchase a pipe, does it matter what I use?
Thanks all!
Stang
rlitman
Long Island
I thought Type L was harder than Type M?
Hardness and thickness are two different things.
Drawn tubing will be pretty hard unless annealed. If it's sold in sticks, it will be hard. If sold in rolls, it will be soft.
M is thin, followed by L which is thicker. K is the thickest. I've only seen K sold by the roll, but you could try and find it by the foot (still off a roll) at a plumbing supply.
L is usually found in sticks, and is not all that flexible. Though you can anneal it with a torch if you wanted to. Even if annealed, vibration (as you'll get off a compressor pump) will work harden it, and it will eventually crack if the aftercooler is not secured firmly to the tank.
There are high temperature braided lines that might be better. You'll want to look at something sold for AC compressor outputs.
engineer2
Chicago burbs
Type K is bendable with a proper tubing bender. You can buy coils of it in 1/2" OD anywhere. (Amazon, MSC)
An alternative would be having a hydraulic hose company bend you up a line in steel. More durable than copper.
StangStang
So what should I buy from the store/amazon? I assume that I have to purchase either type L or M roll, right? My aftercooler is mounted to a wall next to the compressor.
I have -8an male fittings coming off the compressor head and the aftercooler. Could I get a high temp braided line to work?
Lelandwelds
Central Texas
It is all bendable. Some is easier. There are mechanical benders. If all else fails, you can freeze water or pack sand. Crimp the ends.
You anneal copper by heating it up and dropping it into water. You could use aluminum or SS tubing. Compression fittings are easy.
StangStang
I just quoted $200 to make an a/c line..
I have 1/2" compression fittings to 8an coming so I would like to use copper. It's 150psi tank and needs to handle up to 400 degrees of temp. There isn't a minimum of copper I should aim for?? I'll buy a bender I don't care, I just need my compressor to run again.
engineer2
Chicago burbs
Lelandwelds
Central Texas
HVAC is the thinnest of all and is smaller than claimed nominal so the fittings are different. It's good for 600 psi and over 400 degrees.
I think you should confirm all Internet info with Google.
samss
Conway, AR
Find an HVACR supply house. Most of them will sell copper tubing by the foot if you don't need a 50' roll. They will also have flare nuts and flaring tools if you need them.
StangStang
Ok great!
Last question. After I bend the tube to form it to my setup, do I need to heat the bends??
rlitman
Long Island
Ok great!
Well, each time you bend copper, it work hardens a little. Like I pointed out before, a work hardened piece of copper is more likely to crack due to vibration. So, you may get a little more life out of it if you anneal it after bending. Though the best solution would be to clamp it securely so that it doesn't have the chance to vibrate as the pump runs.
StangStang
Yea, unfortunately my aftercooler is mounted to the wall next to the compressor. So, the aftercooler is good for vibration but the new line might have some issues. I can wrap some adel clamps around the tube and run a support to the compressor to help dampen the pipe. Might just work.
engineer2
Chicago burbs
The rubber might stink at 400 deg.
I've seen some compressors run a factory copper tube, so vibrational fatigue must not be a big issue.
StangStang
I found some high temp Adele clamps (700+ degrees).
Very true about the factory copper line. Mine did have one originally. But I need a longer line which may cause a change in harmonics causing earlier fatigue and failure?
Anyway, I appreciate all the help! I found some 10’ 1/2” OD type L tubing at Home Depot and purchased a 1/2” OD tube bender tool. Should work!
