Custom snap on ratchet with insulated handle idea
STEVENC
So I have a replacement #2 insulated on the way, and I am supposed to destroy this one. I figured I will make a custom ratchet out of it. Do you think the guts of the screwdriver will make it difficult to make a handle out of? I do not have access to a lathe and plan on drilling it out with a press so any tips are much appreciated.
STEVENC
I have to figure out if the shaft is pressed in first SO replaces the unit with a new one instead of pressing one in like the other screwdrivers. It looks pressed in to me so with some boiling water a vise and a slide hammer I figure I can get it apart. I wont take it apart till the new one comes in though. I think Ill only be left with a 3/8 or 1/2 hole though
rsanter
visalia ca
My guess would be that the shank slides into the insulating sleve and then into the screwdriver handle
I suspect they don't just replace the shank for liability reasons in that they rate the screwdrivers for insulating and don't want to risk that.
I think the shank will pull out but you will mess the sleve in the process. Then drill out the handle and press it over the ratchet. I don't even think you need to modify the ratchet
Bob
Aquaticbob
Seattle
You might have to modify the ratchet slightly to grab the handle. You can try just pressing it on for a friction fit, but you will for sure need a shop press of some sort to get it on if you plan on having it stay on. If you watch this video:
(How it's made, snap on ratchets) You'll see how it's friction fit on there with the ratchet sort of grabbing the cushion as well
STEVENC
I agree that I will need a shop press, and I think I will wait until I can use my Dads neighbors when I get to that point. I will probably be disassembling the screwdriver tomorrow, and go from there. I watched the video, that was pretty interesting. I think If I can do a tight enough friction fit It will be fine, but if the guts of the screwdriver dont look right, I may end up scrapping the whole idea
jimexcursion
Maine
There was thread on this a while ago with many examples of different ratchets. Can't seem to find it.
STEVENC
I ran in to a bit of a problem. The screwdriver they sent out does not match my set. The old one pulled apart really easily. Hopefully the new one comes out just as easily and I can put that shaft on the new grip
tjmonsen5
Crystal Lake IL
You will probably ruin the integrity of that high voltage screwdriver if you take it apart.. There must be a reason there are no repair blades for these.
STEVENC
it was a pressure fit. shaft was very easy to remove and replace. The metal tip portion is only about an inch and a half with about half of that exposed. that leaves 6-1/2 inches of composite with the handle going over a portion of that. I guess you could ruin the fit if you arent careful.
