Custom tube bending dies JD2
KirkBurner
Norway
I am a noob when it comes to bending, but I understand that the dies I have for my bender is standard.
Anyone here with experience in creating custom dies? I am basically looking to create some Motorcycle handlebars.
so It will be 1 inch or 25mm tubing. but I want "sharper" bends.
So I have to have a shorter radius
How sharp can it be before the pipe collapses on me? anyone got experience in this field?
I use a JD2 bender.
turtleman321
Harrisburg, PA
it all depends on bend radius, wall thickness and material.
I will say for me a 1.5 inch 4.5" radius die has issues sometimes when i try and bend 0.065" wall tubing on my JD2. but sometimes its fine. depends on the batch of material.
dr_clyde
Holland, MI
I've bent a LOT of tube with a JD2 Bender. They're pretty accurate in what they rate the bender for. They sell a variety of dies, and the narrowest radius die they sell for a given size generally is about the limit before you start running into problems.
You can make custom dies, but you probably won't have a lot of luck.
cannuck
Rural SK
Beyond a certain point even the best open die will allow the OD to collapse. Wall thickness and bend radius as each decreases makes wall failure more likely. I have had some luck with compacting blast media and plugging off the tube, but nowhere near as successful as using a mandrel bender.
will335i
IL
^sand works too, or any fine grain media that you can pack in and then get back out after you have completed your bends.
