Cut and cap live PVC
loganb
Omaha, NE
Smaller diameter I have used a sharkbite style ball valve, leave it open, get it on then close it. Don't think that's gonna work on that big if they even make one for 1.25"
duneslider
Riverton, Utah
What about a sharkbite type cap? Gonna be pretty tough to press that cap on with 60psi trying to push it off! Definitely gonna get really wet too.
What about a sharkbite ball valve and have the valve open while you push it on and then close it once you have it properly seated?
thunderalley3
Daytona Beach Fl
I was shown by a plumber that only does underground work on an emergency repair. you need a ball valve with a pvc slip fitting attached.
You need a can of Christy's Red Hot and Blue PVC glue
Leave the ball valve open, put a substantial coat of glue on the pipe after roughing it up with sand paper and the same for the inside of the slip fitting. Work quickly as the glue sets fairly quick. Push the fitting on , twist a little and hold in place for 3-4 minutes and then let it be with the ball valve open for about 10 minutes and then close the valve.
It is messy (water/mud etc) but it works. I worked in a mobile home park that you had to shut the whole park down for a leak. With over 300 homes that was not an option so I have done it many times.
DHCrocks
Hawaii
You could use a "freeze Seal", that will require a considerable amount liquid gas like CO2 or Nitrogen to freeze the water in the line.
I have seen it done at facilities that have Nuclear Reactors.
if you freeze PVC won't it crack?
W
Walkers
Cave Creek Az
I'm curious about your circumstances. ??
I bought an acre and a quarter adjacent to my acre and a quarter. It was split off of a 2.5 acre parcel that was owned by a guy who drilled wells. Both parcels had wells on them, and they were connected together. The guy I bought them from has a niece living there, and her husband is a jackass. It is time to split the wells plumbing apart, but there are no valves. I put valves on my end, so I can shut that off.
I was just hoping to not have to deal with the jackass, cut it, jump a valve on it, and be done. His system needs to get turned off, and the pressure tank drained, so that there is no pressure, then I can cut it and put a valve in.
oldwino
Sonoma County California (wine country)
Like Thunderalley says, this is the only way.
thunderalley3
Daytona Beach Fl
If you own it there is an easy solution. Inform the niece that you need to do a repair on the well, go over, shut it off and cut and cap the pipe. Have caps to cap both ends so if you ever want to use that pipe again it is clean.
PCustoms
VT
I'm confused...
Do you own the well?
Do you own the property the jackass lives at?
Seems like a pretty simple solution if you own everything. If it's his well that you are feeding from it's still simple but requires a little more interaction.
BillK
Beautiful Southern Maryland
I think personally I would pay a plumber whatever it takes to do the job and let the neighbors know that he will be doing it. That way there is no possibility they blame you for any future issues etc.
Either that or get in touch with the guy who actually owns the house and ask him to let his Niece know what you are going to do.
PCustoms
VT
The way I resd the posts are the neighbors own the pipe that the OP wants to modify....
mike93lx
Richmond, VA
To someone that has never done this before, opening a 1.25" line under 60psi of water pressure is going to feel like an absolute catastrophe that they have zero chance of controlling if they can't get the fitting on and glued.
W
Walkers
Cave Creek Az
I'm confused...
No, here are two wells, one on his and one on what is now mine. Hey both used to feed his house on the front acre, but only one was turned on unless there was a problem.
W
Walkers
Cave Creek Az
Used to own. Now it is on my property, but goes over the property line to his, and is connected to his well. They just didn't put any valves in anywhere to make service convenient.
W
Walkers
Cave Creek Az
I was just hoping for an easy way to avoid confrontation. Since there appears to be no convenient way to do it I will just go over there and deal with it.
PCustoms
VT
You're still cutting the pipe tied to his well, right?
I assume his pipe/well will be under pressure?
W
Walkers
Cave Creek Az
Yes. Ideally the plan is to valve my well off, turn off the power to his, drain the bladder tank, cut the pvc, add a valve, then plug the valve.
duneslider
Riverton, Utah
Having nicked a 1" pvc line that was under pressure it was absolutely shocking to me how much and how fast that water came out. I really wouldn't want to try to cut and cap a line with pressure...
PoorUB
Fargo, ND
Is the owner close by and have him stop by and do the negotiations with the renters?
Also and tees in the line should be removed as the water can get stagnant and cause issues down the road.
4x4Pete
Stroud
Is there no possibility that a check valve was installed somewhere? If one well was operating wouldn't it backfeed into the other well?
NUTTSGT
Northern Central Ohio
I'd agree. I know a fire sprinkler puts out a ton of water and it's not even close to 1 1/4".
Norcal
The "jackass" can cooperate or cut the line & they can pay the electric bill with the water running freely.
