Cut diamond plates?
PoorOwner
CA
Aluminum diamond plate .072” thickness
3 ft x 3ft but I need to cut it into 1 ft strips.
Thinking flip it over so it is flat and clamp a guide and then use jigsaw?
readhead
Durango, Co.
Carbide blade on a skilsaw will work fine. Use some cutting wax or WD-40 to keep from clogging the blade. Wear safety glasses. Chips will be flying everywhere.
mdog892001
ohio
Aluminum cutoff wheels for grinder. Also a sawzall with a fine tooth blade
shoot summ
This, .072" is very thin, good blade on a circular saw, I would even consider a table saw. Thin aluminum will cut fine this way.
MikeinNorthWales
SE Pennsylvania
Circular saw or table saw are the machines of choice in my industry. A carbide blade will cut that quickly and clean. As stated, watch the chips!
Alexander
Hudson Valley, New York
I third the table saw (or regular circular saw) suggestions. We spray it down with soapy water to help lube the blade.
If you'll be doing a lot of cutting, I'd suggest getting a triple chip blade, which are usually even labeled for non-ferrous and plastics. HD stocks them in 7 1/4, 10, 12, maybe other sizes.
P
PoorOwner
CA
I have a table saw. And I feel safer to go with than a circular saw . Mostly don’t want it falling at the end of the cut. So it doesn’t hurt the saw if I use the right blade?
It won’t kick back?
lis2323
Id take it to a shop and have them shear it for you. Barring a major screw up you’d be pretty much guaranteed perfect strips.
I THINK even a 16gauge steel rated shear would handle your .072.
A lot of home shops might even be able to handle it for you. Hard to beat using a squaring shear.
dr_clyde
Holland, MI
That's a shear job if I've ever seen one. Take it to a sheet metal shop. I bet they'll do it for a $10 bill.
If not, an nice carbide tipped blade on a table saw will work. Loud and messy but effective.
shoot summ
It won’t kick back?
Wont hurt the saw at all.
Will be noisy, and watch the chips, beyond that it will be quick and easy.
4 FN 27
Minnesnowta
As many mentioned above my first goto would be the Table Saw and some light oil feeding Tread up...
Second Circular Saw, Tread down and light oil.
Third...find a shop with a shear and good hold downs so the sheet doesn't twist as it cuts...and preferably a set of blades that have never seen Stainless Rod Stock. At 12 inches wide with the right blade clearance they should stay pretty flat.
When we Laser or Water Jet we run Tread down...punching in the Turret Press Tread up.
I have cut 3 inch thick slabs of Aluminum with a Circular Saw. Me cutting and my buddy spraying WD-40 from the bottom on the Blade. Long Sleeves, Face Shield, Hat and Ear Plugs are a must.
4 FN 27
Minnesnowta
It won’t kick back?
Yes watch out for the Kickback...Table or Circular wipe down the "sliding surface" with WD-40 so the material doesn't hang up.
I cut some Extruded Tube on a Table Saw once for a customer in their Proto Lab...very dangerous as we were cutting the Tube the long direction to make it into Angles...not the brightest thing to do but lead-time did not allow us to wait for the correct material. We had a few kickbacks due to the material stress relief as it cut...
P
PoorOwner
CA
For a 10" table saw blade how many teeth is preferred? I see 60, 80, 100..
maxpower_hd
Massachusetts
I recently had to cut some aluminum and I used a circular saw with a used Diablo Demo Demon blade in it. It cut just as good as other metal cutting blades I've used. I tried an abrasive metal cutting blade first and it was no match. If you were to get a blade specifically for aluminum I'm sure it would work even better. But the Demo Demon is only about $17.
Marctrees
TX/LA border - Toledo Bend
Op - Listen to above suggestions.
Of course a jigsaw will cut it, but you will not get a nice straitedge EVEN cutting against a clamped guide.. cause the blade will often drift sideways..
Also not as clean and smooth and burr free of a cut anyway.
Marc
ericlar80
California
If using a table saw, make sure to use the blade cover guard and use face protection. I'm not a fan of carbide flying at my face, which is more likely to happen when cutting metal. I would personally use a skil saw with or without a guide, depending on how accurate you need it.
dnschmidt
Phoenix, AZ
When cutting aluminum it is imperative to use a lubricant. The best is something wax based like Boelube or Relton Stik-Kut. However, a good spraying with WD40 works as well.
Zebu Fellenz
Phelps, NY
Table saw and a GOOD face shield are my tools of choice for slicing aluminum up to 1/2" thick. Emphasis on GOOD FACE SHIELD hot aluminum chips hurt more than sawdust! :)
Marctrees
DEAD SERIOUS - Not only a face shield, but also TIGHT fitting glasses/ goggles...
And ideally clothing that will not hold sharp swarf... no fuzzy wool shirts..etc...
The **** goes ALLL over.. will find it in your ears and..
Probably underwear even.
Not joking.
A head/hair cover is very good, otherwise you WILL be picking out numerous swarf unless yer bald.
It is a major mess.
My entire concern is getting a bit of razor sharp swarf in an eye...
Not gonna be cheap.
Not gonna be a happy experience.
The **** seems to have a magical ability to get everywhere..
Did I say that already ??
Definitely can be done, but Really recommend shearing if possible.
Marc
Mr_B
Reading
I always plasma cut tread plate, comes out perfect, cut it on back side using a guide for torch and turn power up and move torch faster, real clean and quick, I done loads of trailers and recovery truck this way .
2ndGearRubber
Pittsburgh
I cut some with a grinder and cutting-wheel today. Not perfect, the edges need buffed to remove burrs afterwards. Did well enough for fabbing up a bumper.
Face protection is a good idea as others mentioned.
Ign
Butte Peak ND
Not joking.
It is a major mess.
Not gonna be cheap.
Marc
Wow, easy! I cut miles of Al tubing and flat bar w just a 12" miter saw. When I sweep up the chips overflow a 5 gal bucket after each job - not exaggerating.
I wear basic eye protection, ears and I do prefer a welders cap to keep it out of my hair. In 9 years of doing this I've felt maybe a couple chips get in my eye and I assume they've been flushed because no problems but honestly any eye doc will tell you RUST in the eye is THE real concern and Al obviously doesn't have this potential.
I'm not saying don't be safe but OP you're not bathing in nuclear waste here. Step back, take a breath - the sky is NOT falling. Use the same common sense you'd use when cutting up a pallet and you'll be fine.
On the list of dangerous things you do everyday, this is WAY down there. Stepping out your front door is far more hazardous
Bigblue&Goldie
I rolled up to a buddies house yesterday and he just go done cutting an .125" sheet of aluminum with a circular saw.......he kept saying "the damn chips were such a mess; it took me longer to clean up the chips than to make the cuts"!
lbhsbz
Long Beach CA
I do aluminum sheet on the table saw all the time...give a shot of WD40 on your cut line.
It'll cut as easy as plywood doorskin.
Marctrees
Cutting tubing or flat bar in a miter saw keeps chips relatively contained.
Very very different than sheet cut w a circular saw.
Table saw not as bad.
I was talking I guess about the circular saw method.
Marc
Marctrees
Just the other day I cut a small amount of 26g steel w a very fine tooth jigsaw.
Workpiece was on a very low knee height bench.
End of day, I still found some tiny chips in my hair.
Hanging on like Sandburrs.
Just one of them could have caused a scratched cornea and lots of headache.
Oh, and unfortunately, I am not a safety gestapo.. Stpidly I do stuff w no glasses most of the time.
"Cutting up a pallet" I would not grab glasses.
This is different.
Marc
