Cut tyvek roll for reduced width
Tundra1
Hi all,
I'm getting close to a point of wrapping my 36x60 12'6"h shop. Tyvek is common in 9x150 rolls and some 3' option. But I'm thinking most efficient will be cut a 9' roll to work better with the 12'6. So would use 9' + 4' and get 6" overlap.
Is this possible to cut a whole roll down with conventional saws? Or will I just end up with a giant ball of Teflon strings and scrap.
Is there a preferred method to apply housewrap when the widths don't add up perfectly?
Thanks!
  • Like
Reactions: Doc
T
Tundra1
Thanks, I appreciate all the feedback. I will double check but HD was out of tyvek stock and Lowe's only had 9' and 3' when I was looking.
jack stand
Lakes Region Maine
Thanks! Any tricks to it? I was thinking maybe I would wrap in masking tape and cut through middle of tape.
When you "are one" with a skillsaw because you make hundreds of cuts a day in any applicable material or situation there's little thought process to mention a tip.
Just fully support the roll, have a firm grip on the saw and simply watch the shoe of the saw for square to the roll. If you're good you can roll and cut in one motion and consider yourself lucky if you meet up with the beginning of the cut exactly. 😆
A chop saw will do it perfectly providing the roll is supported.
