Cutting 1/4" galvanized checker plate
tiredoldironworker
Hello all, due to a structural engineer and his detailer being idiots, we now have to crosscut 200 lineal feet of checker plate that they messed up on. We have ordered the Milwaukee corded 8" metal specific saw and a couple of steel cutting blades. We bought a Diablo steel cutting blade yesterday to put in a new DeWalt 7&1/4" circular saw and I was able to cut 55 feet before it gave up its carbide teeth. Hopefully we will get better performance from the Milwaukee setup. Does anyone have suggestions about best practices and procedures?
GeoBruin
The Milwaukee will make short work of it. I have the cordless version and it's a beast. I suggest you keep the feed rate high, as in push the saw into the work rather than just letting it spin and build up heat. Also, and this probably goes without saying, but try to cut straight and don't let the blade bind up. It's bad for the blade in wood but it's even worse in metal.
speed bump
Butte Montana
At 55 ft on the first blade I would probably grab 3 more and call it good.
We have the Milwaukee 8" saw and it's great for cutting grate and thin plate, occasionally someone will spray some cutting oil when they use it but generally they just let it eat.
tarbellb
Oregon
8" Milky has a cut rate chart, iirc it's 30-40% duty cycle or rather ft per min
In my experience that saw eats blades, especially anything thicker then 1/8"
Buy extra blades, once they're toast the cut will start to (significantly) wonder and take much longer
MJD1
The Milwaukee blades last the longest in my experience. Use a strait edge guide to keep the blade from twisting and keep the depth of cut so less than half of the cutting edge on a tooth protrudes thru the material.
Steve_P
Has anyone used the Makita 7-1/4 blades for cutting steel and compared them to other brands? They're ~2X as much $ as Diablo, but they look "purpose designed" for metal, while the Diablo looks like a blade for wood. I have the Makita metal cutting saw, but I'm still on the first blade; I'm typically not cutting many feet at a time where I'd be able to say it lasted for X feet and do my own comparison.
Makita
Diablo
tarbellb
Oregon
From my usage the Diablo out performed the (USA) Milwaukee branded blade in my M18 Metal circ
The Milwaukee form factor is similar to the Makita? I typically think Makita puts out good stuff, and don't doubt it's a solid blade and worth testing.
But, I find that any of these carbide tipped metal cutting blades are not long for this world and very much a consumable. ROI might not be there.
T
tiredoldironworker
We don't have access to compressed air for a plasma cutter in this rooftop situation. The cuts need to be as straight and as clean as possible. We have to weld the forty or so 5'x8' sheets edges completely all around. This is for a glycol containment tank backup system on the roof of a 60,000 sq ft chiller for a pork sausage processing facility. My boss had already ordered the Milwaukee saw before I cut the first eleven sheets. I was absolutely covered in small hot chips from the DeWalt. Hopefully the chip containment on the Milwaukee will help.
danielbuck
55 feet out of 200? You're 1/4 the way there, I'd just buy a few more blades and finish. But having a saw that is spinning at the correct speed will probably be better in the end, and you'll have it for next time too :)
seber
Deep East Tx.
Are the teeth coming off or just getting dull? If they are coming off, change blades before they get hot. Sharpening carbide tooth blades is easy. Just make a sliding jig and sharpen with an abrasive blade in a table saw.
T
tiredoldironworker
They are breaking off near the weld. The galvanizing seems very hard on them. Hope to have better results tomorrow with the 8" Milwaukee. Blades don't seem to be getting very hot and I am pushing them fairly hard. Cut depth is one tooth below the plate and I am using a 3x3 heavy angle as a rip guide. It's still hard work!
MJD1
Decrease your cutting depth some and your blade life will increase
NUTTSGT
Northern Central Ohio
I missed the galvanized at first. For some reason I thought aluminum :dunno:
If you got 55' out of the first one, I'd probably keep with that method.
When you're done, take one of the blades, paint it gold, mount it to a nice plaque and give it to the Structural Engineer along with a tag that says "Measure Twice, Cut Once."
