NewShockerGuy
I would just use a hack saw honestly. Tape the bucket off to desired height. And then simply take the hack saw and cut right above the line or mark that you made. Should come out pretty perfect as long as you aren't trying to rush through the job. I've done something similar when I was modifiying tubes for a car project. The tubes were about 12" in diameter. Took me about 5 minutes to completey cut through the tubes and if there was any plastic that was a little jagged I would simply take an exacto knife or razor blade and trim it off. Then as someone noted take a torch or heat and you can round the edge that you just cut.
I feel like a table saw is asking to get messed up or launching the bucket back at you..lol
-Nigel
-Nigel
