Cutting an oxygen tank.....
tlmartin84
West Virginia
I have an empty tank, been sitting now without fittings on it, wide open to the atmosphere for roughly six months.
I need to cut the ends off of it, I will probably use a grinder with a cutoff on it.
Do I have any issues?
cdaiscool
Ann Arbor, MI
If you're super worried about it, you can fill it with some water and then pour it back out. That's how I'm going to make sure a gasoline tank that I'm going to have cut and welded is empty of fumes.
But I cannot offer any help as to whether it's safe as-is or not.
kbs2244
standing upright?
I don't know if straight OX is heavier than air, but if you lay it down he heavier gas will flow out.
Even so, with OX in it all that should happen is your sparks will burn hotter and faster.
Use spark shields and have water near by.
rsanter
visalia ca
No issues that I see
If you have any worries just blow compressed air in it and that will be sure that you are good to,go
Bob
laser3kw
northen IL
Finally, someone that understands that oxygen is not explosive like the movies show it to be.
You can shot a full cylinder, knock the valve off and all it will do is jet around, NOT blow up in a huge ball of flames.
ps - they make nice wind chimes with a deep reverb tone.
rlitman
Long Island
You do not understand the dangers of highly compressed oxygen. People have tried to drill holes into oxygen cylinders. The results are almost always movie grade explosions. The velocity of the oxygen escaping can produce enough heat to set the STEEL of the cylinder walls on fire and burn the metal as fuel. Similar things have been known to happen when aluminum valve bodies are used. Yeah, if the valve is brass, it will probably jet around like you describe, but you never know.
zkling
Done it many a times. Just rinse it out for peace of mind. What I do is wrap a thick piece of tape and string around where the cut is, double check with a tape measure at ~6 points. Then draw a chalk line at the edge of the tape where I want the cut, remove the tape and then go at it with an angle grinder and cutoff wheel. Don't try to make a continuous cut, highly doubtful you will be able to make it all the way around, perpendicular. Instead make a plunge cut, drag it in the cut a bit, then retract and make another plunge cut a few inches away. Keep checking against your reference line.
Oxygen does not burn. It combines with other fuels to make them burn.
Thus why it is classified as an oxidizer.
BigMike782
Leave all or part of the neck on or the ring will not be what you hope for......DAMHIK:(
I cut the neck out, turn it in the lathe for a flat base, paint it a nice color and put valve back in and it makes a nice paper weight......especially when it has the neck ring of the company you used to work for.
3 Gun Shooter
The OP has removed the valve so it is atmosphere only in the cylinder. I'd have no problem cutting the top and bottom off with a saw or cutting wheel in an angle grinder.
rlitman
Long Island
Correct. A second reply now to my quote taken out of context. Try reading more.
On that note, once the valve is removed from an oxygen cylinder, feel free to cut it right away. The remaining oxygen at atmospheric pressure is not going to cause any issues. There is no need to blow it out with air, or fill it with water, or any of the other suggestions above. Yes, 100% oxygen at atmospheric pressure can cause issues if it saturates clothing, but that's not a concern here.
Tim-Bob
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALERT FOR CDAISCOOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!WATER AND PETROLEUM DO NOT MIX. THERE WILL STILL BE RESIDUE IN THE TANK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!AND IT COULD STILL IGNITE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You need to "inert" the tank. The easiest way is to run exhaust from a gasoline powered vehicle into the tank for 10-15 minutes before any cutting/welding operation. Keep the exhaust running while doing your work and until is has cooled down afterwards. The exhaust shouldn't have any available oxygen, so no combustion should occur inside of the tank. I hate cleaning up blown apart/burned up mechanics after they've messed with a fuel tank, and I bet your loved ones would too.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
cdaiscool
Ann Arbor, MI
Thanks for the head's up! Was told this by the guy that said he'd weld it up, plus owns his own performance (not welding) shop. I'll let him know this process instead so he doesn't increase his 'pieces' count by 50.
ovrrdrive
Central Florida
In true internet fashion this thread went from "you'll be fine" to "you'll blow up half the country" and back to "you'll be fine" in record time... lol
Tim-Bob
I wasn't trying to be dramatic, or sensationalize anything. In fact, my post was meant for cdaiscool, and not referring to the O2 tank cutting at all. I've never hacked up an O2 tank, but I've had lots to do with fuel tanks. The original poster asked for advice and received it.
Cdaiscool had a plan that I considered to be potentially inadequate. It probably would have gone off without a hitch, but since I have seen the results of a fuel tank explosion due to inadequate inerting, I just felt obliged to give him a heads up.
I hope I didn't upset or offend anyone.
gbh
Yes, but it usually takes 3 pages to do so.:lol:
cdaiscool
Ann Arbor, MI
I personally didn't feel upset or offended. I'd rather be told something I'm doing is unsafe than blow up later.
