Cutting baseboard under kitchen cabinet
branimal
How can I cut this base so door opens a bit wider? I'd like to keep the top profile of the base. Is there some mitering technique?
djbmw
Ottawa, Ontario, Canada
Just end the baseboard 1/2" before the door. Use quarter round past that if you really feel the need, or just caulk the last inch of drywall to floor. Example pics of how to finish baseboard ends attached.
FrankLee
seMI, 48317
Shim the hinges inside the frame and move the upper panel over to match the door.
It looks like you have about 1/2" on the right side.
hobie18
There are hinges that would solve this.
otherwise:
Add new strip of wood to move hinges to the right.
If you cannot flip door, move cabinet, etc...
wssix99
Chicago, IL
As said above, fillers are used against the wall to give you the buffer. They also allow you to adjust for the wall, which is usually not straight. (like the cabinets)
JKinAK
If you can’t/don’t want to add a filler: consider ripping a 3/4” (or whatever the minimum is to clear the door) out of the flat section of the baseboard. Consider doing this for the entire room with these cabinets. Consider taller bases for the cabinets. Consider routing a 45 along the full bottom front of the door sufficient to clear the baseboard. Or don’t.
larry4406
Northern Virginia
I have had to resort to notching the top of the base and cutting it backwards at 45 degrees when there has been a cabinet/layout bust that would not allow a filler to be used. Notched to run under the cabinet and fill the toe kick and 45'd about 1/2" back from the cabinet frame.
Door will still not swing a full 90 degree.
Best case is the filler for the full overlay cabinet.
+1 on cheating the height of the base if it does not run into another space/room.
Michigan Mike
Kalamazoo Mi.
I reccomended the filler earlier but am liking switching the swing of the door. It is a little inconveniant for access to the cabinet but if it is not possible to move the cabinet over it is the easy fix.
lolaetype
North Western Arkansas
Or turn the door around?
That's what I would do unless moving the door so the hinges are on the right side would create another interference issue. And it's an easy fix on virtually all factory built cabinets. My second choice would be to reposition the cabinet with a filler between it and the wall. I'm picky and OCD so any bodge involving cutting the base to accommodate the cabinet door would annoy me every time I looked at it.
