Cutting control joints in polished concrete floor
tookien
Hi,
I want to make control joint cuts in a polished concrete garage floor.
Is there going to be any issue cutting with a segmented diamond blade since there was a densifier used?
Thank you
Sumboodie
AK
Definitely can cut concrete not green. And polishing can be done as part of the slab work with power trowel. Day of pour, maybe next day.
ConCretin
Central Maine
Polishing and densifying typically occurs after a slab has reached strength. If that's the case, it's far too late to control cracking with control joints. Your slab has cracked as much as it's going to. If you want to cut some lines for decorative purposes, you shouldn't have any problems doing so but if it's not done well, you will have permanently messed up your new floor.
T
tookien
The reason I am doing it is mostly for aesthetic / decorative appeal primarily.
I won't be going more than 5/8th of an inch in.
I just want to know if the segmented diamond blade will be adequate as the polished concrete was densified, and thought maybe the densified concrete would give some trouble.
It seems ConCretin has answered my question though.
Thank you once more
T
tookien
Yep, iirc the concrete has to still be green. So just enjoy your concrete before it cracks.
The concrete has already cracked long ago.
I am doing some maintenance to it.
It's just all about aesthetic appeal at this point.
ConCretin
Central Maine
Densifier isn't going to maker the concrete noticeably more difficult to cut. The question is the best type of saw to use and whether to cut wet or dry. Do you want to deal with dust or slurry? The other thing to consider is that the smaller the device & blade, the closer you'll be able to get to walls, etc but the harder it will be to get a straight cut. Is it a finished space? Can you use gasoline powered equipment or would electric be required.
As I sit here, I'm not sure what I'd use. Early entry saws are made for this but won't work well on hardened concrete. Larger walk behind saws would be fine for larger areas, are relatively easy to keep straight and work with water. If it's a small area, you might be stuck with a circular saw, which would be painfully slow and dusty. What's your plan?
T
tookien
Hey, thanks for the response.
My plan is to get some OSB cuts secured with a few concrete screws and line up the circular saw to ensure I get some straight cuts as I don't want to mess it up.
I want to avoid dust and use some water, so wet, going really slow and steady.
The area is about 18 by 20 feet.
I want to divide the 18 by 3 so 6 foot sections. and cut one in the middle of the 20 at 10 feet.
3 control joints in total across.
The plan after is to seal the joints up as well as the thin hairline cracks with epoxy, and then polish it out.
Walkers
Cave Creek Az
Gotcha. I have cut deep and long with the diamond blades in a skillsaw, usually not for decorative purposes. Easiest with a helper holding a spray bottle of water and a shop vac.
T
tookien
Yes! Best to have two people, one cutting, one vacuuming. Rinse well before it dries.
Thanks. What about polishing the concrete wet as I need to do some of that in some areas before moving on to higher grits. Does that need to be constantly vacuumed?
