Cutting down a Snap On Allen Socket
DPDISXR4Ti
New York
I recently purchased a 1/2" drive 8mm Allen socket (p/n SAM8E) for the primary purpose of removing the rear caliper bracket bolts from an Audi A4. They are notoriously difficult to remove, both for the tight access and the inhuman force required to remove them.
Because of the tight clearance, a "stubby" socket is needed, but Snap-on and others only make a short version in 3/8" drive, not 1/2". I want to use my 1/2" breaker bar.
Long story short, I want to cut down the length of the bit on the socket. Any issue doing that? Will a standard, good quality, hack-saw blade do the job?
rlitman
Long Island
I would expect a quality allen socket to be too hard to be cut with a hack saw. I've cut allen keys with an abrasive cutoff wheel, but you'll want to dip them frequently in water to keep from ruining the temper.
R. Johnson
CT
When I did mine I used an allen key with a small pipe for leverage.
md21722
Mt Juliet, TN
Yeah just use a cutoff wheel. I have cut down Snappy gold colored bits before to work on German cars. Or buy a German hex driver. I prefer Hazet/Stahlwille drivers for hex, XZN, etc...
Heavy Metal Doctor
Mason Dixon Line
No issue at all. I've done it with a few SO drivers. Clamp the driver in a vice and use a 4" cut-off wheel to grind through it - hold it a s straight / square as you can so it's doesn't look like **** when you're done.
afazz
Pittsburgh, PA
To echo the comments above, cutting it down with an abrasive tool isn't much of a problem as long as you keep it from overheating. I also doubt a hacksaw would cut it.
If you're interested in keeping it Snap-on, I wonder if you could pop an FAMXS8E2 replacement bit into your SAM8E socket?
shawhite
Why not just replace the Allen portion with a stubby one. I bet your snap on guy will do it for free.
D
DPDISXR4Ti
New York
Stahlwille 54-8 only $9. It may fit:
http://www.ebay.com/itm/351955784059
That one is 60mm long, which is pretty nearly the same as the Snap-On.
Hazet 985-8 $26.60. A true 1/2" stubby that will certainly work:
http://www.ebay.com/itm/like/360731709736?lpid=82&chn=ps&ul_noapp=true
At 38mm length, that one would work. It's priced about the same as the
ASSENMACHER AHS 3049-8
http://www.autotoolworld.com/Assenm..._126175.html?gclid=CM2Mu_6PytECFYmLswodQW8DjQ
I'm just not sure I want to spend $25 for another tool I'll use so infrequently.
RAYJAY
UNION DALE PA
PIECE OF 8MM HEX cut to your length of choice and a 8 mm 1/2 drive socket epoxy hex in socket if needed
we do it at work all the time
D
DPDISXR4Ti
New York
I think this will be the route I go. Thanks for all the feedback.
gdocktor3
Connecticut
If an Allen wrench with a pipe will work, why not use the stubby 3/8" drive with a breaker bar and a pipe on that?
Edit: I thought you already had the stubby 3/8 drive socket. Try the Allen wrench before cutting the expensive Snap On bit. No?
D
DPDISXR4Ti
New York
I considered that (pretty sure it would require a 1/2" pipe), but I haven't got a good quality 3/8" drive breaker bar. I could much more readily justify that purchase though, so you may be on to something. :)
D
DPDISXR4Ti
New York
I actually don't need a stubby for the 3/8" socket since the head of the 3/8" breaker bar is smaller.
T45
md21722
Mt Juliet, TN
Another thing I do in tight clearance areas is use a serpentine belt tool. This is similar to what the other poster is saying bout the flat stock. The serpentine belt tool is basically flat stock with a 3/8" (or 1/2") drive head welded on. Often it gives just that extra bit of clearance that you need.
Heavy Metal Doctor
Mason Dixon Line
I have a number of cut off allen wrench pieces I use for very tight spots -- slip the little stub into the bolt (or hydraulic system port plug as is often the case for my work) and then use a regular wrench on it.
Ign
Butte Peak ND
I've machined sockets in the lathe w zero issue. I'd be surprised if a quality carbide insert wouldn't cut it easily.
VIM makes some nice stubby hex, affordable too.
Tim37
The bits running about $10 off the truck you could buy a stubby bit and put in it.
Or hell I'm with ya I would cut it short. I have had them round off and I just used a cut off wheel and chopped a little off the top so I could keep on working my so guy was ok with it
MShaw
York, Pa.
"A 3/8" cast iron pipe would be the one to try,"
No, black iron. Cast iron would snap like a toothpick.
Cope
Houston, TX
This is an 8 mm tool, does it need 1/2 drive? How often do you do this?
From OP's original post: "They are notoriously difficult to remove, both for the tight access and the inhuman force required to remove them."
Shaners256
Milwaukee
Got an 8 mm,,, how hard can it be? I do them with a Walmart set.
What year A4?
I have a B5 A4 that I have removed the rear caliper brackets many times. I doubt they changed too much even with the newer models.
I just use an 8mm hex socket, mine is 3/8" drive, with a short 3" extension. The extension is required to get the drive end past the stabilizer link that is in the way. The ratchet would hit the stabilizer link as you remove the screw, but the smaller diameter of the extension allows you to get past the stabilizer link.
bmwpowere36m3
Don't over-think it... you got the bit already. Cut it and use it. Seems crazy, but the # of good tools we've bent, ground or re-worked is a bit sad. At he end of the day it's got a job to do. Usually the tool is the least expensive part of the whole equation.
toolslut6.0
Ive cut down a bunch of mac usa allen sockets meyric and standard. Just cut the off with cut off wheel dont worry so much about heat just drive the bit out and flip it so the factory end is being used to drive the bolt
nbpt100
Massachusetts
Every Idea I have read on here will work with the exception of the use of the hack saw or band saw to cut the hex bit. Use what you have and don't worry too much. More than 9 ways to skin this cat.
SuzukiGS750EZ
I HATE THOSE! I want to say i modified an allen key and used a jack handle for leverage. Those things are horrible. The first time i came across one i thought to myself "What jackass decided to do this!?". I'd still like to know...
nbpt100
Massachusetts
Socket head cap bolts are pretty are relatively common on brake calipers and brackets. The Germain car manufacturers seems to really like them.
Look on the bright side, it is better than a Torx bolt which are also sometimes used.
SuzukiGS750EZ
The a4 calipers are the ones which the bolt is facing inward underneath the bracket that's on the underside if the car, right? If I explained that right lol. Not enough room for a ratchet let alone a full size Allen key. Or am I thinking of another audi?
