Cutting fluid for stainless and Aluminium?
jeff000
Been drilling a lot of stainless at work lately, and it *****. I have rapid tap, but it really doesn't seem like it does much besides make some smoke.
Also always have drilled aluminium a lot, and even with rapid tap I feel like the bits just don't last as long as I think they should.
It's 100% with cordless drills, and we use the Walter SST 118 degree drill bits.
I don't have the ability to buy new bits as the boss buys in bulk (10,000 at a time) and we still have almost all of them from the last order.
I do have the ability to buy cutting fluid or something else like that to help. I like rapid tap on steel, but it seems much less effective on everything else.
Thanks.
Thumper68
Duluth MN
I use alumatap or wd40 on alum but have been trying Anchor lube on everything with good results.
You can get a free sample here http://www.anchorlube.com/
dr_clyde
Holland, MI
You want something without sulfur for stainless. So the dark, smelly threading oil doesn't work worth a ****. My buddy has a fairly good size machine shop that does mostly stainless, and he uses Tap Magic on the drill press and for manual drilling. Master Chemical TRIM E206 water soluble oil for the lathes and mills.
I use Union Butterfield drilling and tapping fluid with great success on stainless.
For aluminum, tapmatic and WD-40 work pretty good.
nehog
Jaffrey, NH
I always found WD-40 to be inferior on aluminum. What I found that worked well was (used) ATF (Dextron). Cost was acceptable (free, we generated a lot of it that was changed out by age and not wear), and it lubricated well for both cutting and drilling/tapping.
bad_idea
Pasquotank, NC
Another vote for anchorlube. The stuff makes the bits cut like crazy and they last forever. It is water based, so no issues with hazmat. It will freeze, so keep indoors. Love the stuff. Wipes up easy too, with minimal mess.
TheOtherChris
SE Idaho
+1
I use ATF for machining aluminum as well. Very happy with it.
Fixnair
Sapulpa OK
I use bees wax for drilling & tapping Aluminum. Leaves a good finish when used on the lathe with HSS tools too.
I'll have to try ATF though.
zkling
About the best for stainless is Moly Dee, but it's not cheap, thankfully all you need is just a bit to work. Cool Tool works pretty well and is cheaper. WD40 is hard to beat for non flood applications of aluminum. I prefer the non aerosol, more controllable.
